waveav@hotmail.com
buttons / popups hidden behind background why ?
Feb 24, 2013 12:34 PM
In CS5.5 the popup button areas I draw on an ' over ' state are drawn under the background - whether background is a bitmap or sold color.  The corresponding popup text also appears behind the background.  Arranging and sending to front or back doesn't help.  I had this working before and suddenly I can't do it.....I'm trying to make a map with rollover popup text.  Making the background layer invisible allows construction but the swf  has hidden popups.
This is the quick tut I learned it on ...followed it and it worked at first.  Now following it doesn't work for anything new.  Tried on 2 computers. Does it work for anyone?
waveav.us/rollover.pdf
Thanks!
  • kglad
    Jul 21, 2002
    Feb 24, 2013 1:10 PM   in reply to waveav@hotmail.com
    is the parent of the background and the parent of the popup the same?
    if yes, that re-adding the popup to the display list will add it above the background.
    if no, you will need to rethink your setup or re-add the parent of the popup so it's above the parent of the background.
  • kglad
    Jul 21, 2002
    Feb 24, 2013 4:16 PM   in reply to waveav@hotmail.com
    is your problem resolved?
