Marissa2742485
Output Errors
Feb 24, 2013 1:22 PM
I am hoping someone can help me. I am getting these errors except eveything seems to be defined. Please let me know if I overlooked something or what I am doing wrong thankyou.
Code
package info.mixnwithmarissa.cakecreater {
          import flash.display.MovieClip;
          import flash.events.Event;
          import flash.events.MouseEvent;
          import flash.net.URLRequest;
          import flash.net.URLLoader;
          import flash.events.IOErrorEvent;
          import flash.events.ProgressEvent;
          import flash.display.Loader;
          public class Main extends MovieClip {
                    private var intro:MovieClip;
                    private var startt:MovieClip;
                    private var setting:MovieClip;
                    //private var game:MovieClip;
                    private var currentState:String;
                    private var xmlURL:URLRequest;
                    private var xmlLdr:URLLoader;
                    private var imgURL:URLRequest;
                    private var imgLdr:Loader;
                    private var swfURL:URLRequest;
                    private var swfLdr:Loader;
                    public var xmlObj:XML;
                    private var loaderDisplay:MovieClip;
                    public var mainXML:XML;
                              public function Main() {
                              xmlURL = new URLRequest("xml/Appxml.xml")
                              xmlLdr = new URLLoader();
                              xmlLdr.addEventListener(Event.COMPLETE,onXMLLoaded);
                              xmlLdr.addEventListener(IOErrorEvent.IO_ERROR,onIOErro r);
                              xmlLdr.load(xmlURL);
                              private function onXMLLoaded(evt:Event):void{
                              mainXML = new XML( xmlLdr.data);
                              //trace(mainXML);
                              //E4X (ECMA for XML) uses dot syntax to "drill down" to child elements and the @ to access attribute data, and [] to access by element index.
                              //trace(mainXML.theme.music.@src);
                              //trace("background image: "+mainXML.theme.@bg);
                                          //trace("theme music: "+mainXML.theme.@music);
                                          imgURL = new URLRequest(mainXML.theme.@bg);
                                          imgLdr = new Loader();
                                          //Note: Loader objects are display objects, so they must be added to the display list
                                          addChild(imgLdr);
                                          imgLdr.contentLoaderInfo.addEventListener(Event.COMPLETE,onImgLoaded) ;
                                          imgLdr.contentLoaderInfo.addEventListener(ProgressEvent.PROGRESS,onIm gLoadProgress);
                                          imgLdr.load(imgURL);
                                          loaderDisplay = new ProgBar();
                                          addChild(loaderDisplay);
                                          //position
                                          loaderDisplay.x = 120;
                                          loaderDisplay.y = 200;
                                          swfURL = new URLRequest(xmlObj.theme.@anim);
                                          swfLdr = new Loader();
                                          //could add below existing onjects to apear beneath them
                                          addChildAt(swfLdr,0);
                                          swfLdr.load(swfURL);
                              intro = new Intro();
                              this.addChild(intro);
                              currentState = "intro";
                       private function onImgLoadProgress(evt:ProgressEvent):void{
                              //trace("Load progress!");
                              //trace(imgLdr.contentLoaderInfo.bytesLoaded);
                              var loaded:Number = imgLdr.contentLoaderInfo.bytesLoaded;
                              var total:Number = imgLdr.contentLoaderInfo.bytesTotal;
                              var percent:Number = Math.round(loaded/total*100);
                              loaderDisplay.percentField.text = percent;
                              loaderDisplay.gotoAndStop(percent);
                              //trace("Percent Loaded = "(Math.round(loaded/total*100))+"%");
                    private function onImgLoaded(evt:Event):void{
                              //trace("Image loaded!");
                              removeChild(loaderDisplay);
                              imgLdr.x = 20;
                              imgLdr.y = 20;
                              imgLdr.width = 200;
                              //solve for new height maintaining aspect ration (so it doesn't look streched)
                              var origW:Number = imgLdr.contentLoaderInfo.width;
                              var origH:Number = imgLdr.contentLoaderInfo.height;
                              var newHeight:Number = origH*200/origW;
                              imgLdr.height= newHeight;
                              //could centre it too
                              imgLdr.y = stage.stageHeight/2-imgLdr.height/2;
                              private function onIOError(evt:IOErrorEvent):void{
                                        //trace("XML loading error!!!");
                              public function changeState(newState:String):void{
                              switch(currentState){
                                        case "intro":
                                                  removeChild(intro);
                                                  break;
                                        case "start":
                                                  removeChild(startt);
                                                  break;
                                                  case "setting":
                                                  removeChild(setting);
                                                  break;
                                                  //case "game":
//                                                  game = new Game();
//                                                  removeChild(game);
//                                                  break;
                              switch(newState){
                                        case "intro":
                                                  addChild(intro);
                                                  break;
                                        case "start":
                                                  startt = new Startt();
                                                  addChild(startt);
                                                  break;
                                        case "setting":
                                                  setting = new Setting();
                                                  addChild(setting);
                                                  break;
                                        //case "game":
//                                                  addChild(game);
//                                                  break;
                              currentState = newState;
Output Errors
TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at info.mixnwithmarissa.cakecreater::Main/onXMLLoaded()
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at flash.net::URLLoader/onComplete()
TypeError: Error #1010: A term is undefined and has no properties.
          at info.mixnwithmarissa.cakecreater::Main/onImgLoadProgress()
    Feb 25, 2013 11:19 AM   in reply to Marissa2742485
    I am surprised you are not getting line numbers. Are you not running a debug build?
