We are using Adobe Captivate 6.0. We are using imported audio files as the voicover for the slides. While plyaing the final published exe, it runs normal. However, if I use the slidebar at the bottom of the slide for moving back and forth, the audio goes away while the slide continues to play. Can anyone please advise as to why this could be happening and how to resolve the issue? Appreciate any urgent help on this.
Hello there,
Have you inserted the audio on the slides or on the objects?
Can you increase the slide quality to 24-bit (slide properties), then republish the project and see whether that helps?
Thanks.
