TanatRoadhamhae
Illustrator CS6 won't run. Entry Point Not Found
Feb 24, 2013 11:01 PM
Cannot get Illustrator CS6 to run. All othe CS6 components are running fine.
Every time I try to start Illustrator I get error message:
The procedure entry point
?AcquireVarient@ImageInterface@drawbot@dvaui@@QEBA?BV?intrusive_ptr@UI mageInterface@drawbot@dvaui@@@boost@@V?rational@J@5@@Z could not be located in the dynamic link library dvaui.dll.
This is on a Window 7 Pro PC. CS5 previously ran fine, but computer was rebuilt after a harddrive crash then loaded with CS6 and this problem began. CS6 installation on laptop works fine, so downloaded files are OK.
I have tried to uninstall and reinstall twice, but always the same result.
    Feb 25, 2013 12:51 AM   in reply to TanatRoadhamhae
    Update your graphics driver.
    Mylenium
    Apr 20, 2013 10:43 AM   in reply to TanatRoadhamhae
    Had same problem.  Uninstalled and reinstalled, but still no success.  Then I uninstalled, deleted everything in the ...\Programs\Adobe\* folders and reinstalled, and everything worked fine.  Seems like the file that was corrupt and causing the problem is not removed and replaced by uninstall/reinstall, but deleting everything allows a good copy to be installed.
