Hi!
I'm new to APE11, and now I'm having a little problem. I've used to create a scoreboard on my gamevideo by creating a title text-field to the video. Earlier with different program (for example Pinnacle Studio) it was easiest to do by creating the title, and making it last from beginning to end. And when the score in the video changes, just split the text clip at the moment I want to change the score and change the text after the clip point. But now in APE11 if I change the text after the split point, it also changes the text before the split point.
What am I doing wrong? Or what would be the easiest way to do this? Copy - Paste isn't the correct answer, because then I would have to change, not onyl the score text, but also the time that the score lasts.
I hope that you get the point I'm trying to explain, and can help me..
As I say in my books, this is because when you split oor copy a title you're creating two clones of the same title.
Instead, right-click on the title in your Project Assets panel and select Duplicate. You can then edit your duplicate independent of the original.
Meantime, if you're new to the program, you may want to check out my free 8 part Basic Training tutorial series.
Steve has given you the correct method - Duplicate Title, and all of those Duplicates will be based on the design of the first, then you just change the "score," as needed, in each Duplicate. This article goes into a bit more detail on handling Titles in PrE: http://forums.adobe.com/thread/1131177?tstart=0
The way that Premiere handles Titles differs from that of some other NLE (Non Linear Editor) programs.
Thank you both for you help. That helps a little, but it is still quite complicated way. My main use for editor is for making videos of basketball games. I'm adding scoreboard to the video, and there usually comes need to update the score about 100 times a game. So, if I have to create a duplicate for every update, and then also adjust the time that the title lasts and change the score, it will be quite slow compared to method that was possible on PS (There I could just split title on the timeline, and change the score and it was ready). There was other problems in using PS, so thats why I'm looking for new software.
But thanks anyway, and I have to browse through those links you sent!
One function, that might save some time, would be to create you "scoreboard" Title, with no scores added yet. When you have finished with that, go to File>Export>Title, and use that to Save the scoreboard as a Title Template (PRTL file). That Template can be used over and over, and you can as many Instances of it, as would be required for all the score changes - just edit each, with the score, as is necessary. Note: PRTL Title Templates can only be used and edited by Premiere.
North America
Asia Pacific
