Arthur010110
OpenGl Enabling problem. Help ASAP :(
Feb 25, 2013 11:21 AM
Tags: #opengl
Hi there. I need help. How can i enabe OpenGL in my Photoshop CS6. I have GTX 650 Video Card.
Here is screen. http://s1055.beta.photobucket.com/user/dskdrago/media/Capture-3_zps0d2 5260b.png.html?sort=3&o=0
    Feb 25, 2013 11:25 AM   in reply to Arthur010110
    The 3D preferences won't tell us anything.
    The Performance preferences might tell us something.
    But Help->System Info will tell us the most about your video card and drivers.
    Most likely you have an out of date driver, or just bugs in your driver that prevent OpenGL from working correctly.
    Feb 28, 2013 10:27 AM   in reply to Arthur010110
    According to that, OpenGL is enabled and working.
    OpenCL is not enabled, because the driver does not support it.
    But you also haven't installed any of the Photoshop updates, and you need to go install the updates.
    Mar 1, 2013 2:33 AM   in reply to Arthur010110
    To download and install the latest updates for photoshop cs6, go to Help>Updates from within photoshop cs6.
    Your OpenGL is clearly enabled in photoshop cs6. (Use Graphics Processor is enabled)
    Is there something in photoshop that requires OpenGL that's not working?
    Something else that i notice is you have the ram (memory usage) for photoshop to use set to 100%
    You should probably set it to around 60% to 75%
    Mar 1, 2013 7:27 AM   in reply to Arthur010110
    Can you launch Bridge and choose Help>Updates...?
    Also, you have Windows 7 64 bit and you're running the 32bit of the application. have you tried running the 64bit version of the application?
    Mar 1, 2013 11:35 AM   in reply to Arthur010110
    Have you tried resetting preferences?  Start PS and immediatly hold down Crtl Alt Shift keys.  If fast enough you will get a reset window.   If you see the splash screen you are too late.
    Mar 1, 2013 11:39 AM   in reply to Arthur010110
    That's an OS error, not a Photoshop error.
    That means that something is corrupt with the application or OS install.
    Mar 2, 2013 10:32 AM   in reply to Arthur010110
    That would be a hint that something is seriously wrong with your display driver.
