terryjohnpratt
Bridge won't let me trash a file
Feb 25, 2013 3:43 PM
I am told I do not have permissiopn to trash files??
  • Omke Oudeman
    Nov 27, 2004
    Feb 25, 2013 4:06 PM   in reply to terryjohnpratt
    If Bridge tells you so then it might be true…
    But seriously, can you provide more details about your set up, system and versions and what files are you trying to trash and how are you trying to trash them (content panel or else, from a network , your start up disk, external, etc.)
    Feb 25, 2013 5:42 PM   in reply to terryjohnpratt
    You are most likely running into an ownership problem.  You should google this.  Here is one link http://www.macobserver.com/tmo/article/setting_the_ownership_of_a_shar ed_mac_disk
  • Omke Oudeman
    Nov 27, 2004
    Feb 26, 2013 12:11 AM   in reply to terryjohnpratt
    This is my hoe compute an I am admin
    The link Curt provided may be a bit 'in the deep' with Terminal needed.
    Open the Apple Disk utility in the utilities folder (applications / utilities) and choose the start up disk in the side bar, then run the 'check and repair permissions' option.
    A short route may also be to select the external disk in Finder and choose 'get info' from the File menu (or Cmd+i). At the bottom of this window you can find the section 'share and permissions'. inhere shows the info for the user, staff and everyone. User and staff should preferable show 'read and write'. You need the admin password to change those permissions.
    (but also run a check and repair permissions, it is a good maintenance for your system, also look at 'Cocktail', a cheap and good maintenance application for the Mac)
  • Omke Oudeman
    Nov 27, 2004
    Feb 26, 2013 9:20 AM   in reply to terryjohnpratt
    Of my 3 HDs only ONE has a check box"ignore ownership", that "one" lets me delete N OT the other 2.
    If the ignore ownership message is selected I would think everyone can freely read and write to that disk. I would prefer to choose Read and write permission for both user and staff and read only for everyone.
    It is a simple change, you only have to click on the lock, set your admin password and change the permission, after that you should be able to delete files form Bridge from both disks
    Otherwise if still not after changing permission try a reset of Bridge Preferences, often cures the strangest of problems.
