How can I make a pop up bubble with a shadow appear when I hover over something. I am trying to use spry tool tip but I can't change the shape. Grrr. Thanks!
Spry has been deprecated and is no longer officially supported by Adobe - http://blogs.adobe.com/dreamweaver/2012/08/update-on-adobe-spry-framew ork-availability.html
And for your requirement, there are tons of jQuery plug-ins that can do the trick - they're all tried & tested to be cross-browser compatible. They can give much better visual appeal as well.
One of those is - http://code.drewwilson.com/entry/tiptip-jquery-plugin
If you want to learn how to code one, there's a great tutorial here - http://jqueryfordesigners.com/coda-popup-bubbles/ - this tutorial showcases the tooltip used on http://www.panic.com/coda
Good luck!
-ST
Thanks for the help. However, now I have to learn javascript as well as
Jquery?! Sheesh. Ok, though. After taking some basic tutorials on these
scripting languages I have tried to install my first Jquery Plugin for a
tooltip from http://calebjacob.com/tooltipster/. I have successfully
linked the two needed css and js files into my site, added jquery from
google to my site, and added the correct script and links. The plugin
still doesn't work and when I edit the css or js files associated with this
plugin no changes happen to the webpage. In fact, I can delete them if I
wanted to and nothing would happen. What do you think the problem is?!
On Tue, Feb 26, 2013 at 10:40 AM, Sudarshan Thiagarajan <
North America
Asia Pacific
