sgribber
Best Export Setting for TV 1080 with constant FPS
Feb 26, 2013 10:09 AM
Tags: #for #settings #export #playback #choppy #to #dslr #tv #footage
1080 23.976fps  DSLR footage
Coming from Final Cut Pro,  I would export a ProRes 1080 mov file for my TV.  This would give me a high quality playback.
I have experimented with several export options in PP 6 and noticed choppy playback on my TV.  Upon closer inspection, the FPS appears to be changing with each frame.
What settings do I need for a constant 24fps with a high bitrate ?
  • joe bloe premiere
    Dec 6, 2009
    Feb 26, 2013 11:11 AM   in reply to sgribber
    ...noticed choppy playback on my TV.  Upon closer inspection, the FPS appears to be changing with each frame.
    What file type and codec did you export for viewing on your TV?
    What are you using to play back on the TV, and what is telling you the fps is changing?
    Does the file play smoothly if re-imported into Premiere?
    Whatever fps setting you use on export should not vary or be altered.
    Feb 26, 2013 11:53 AM   in reply to sgribber
    Maybe your laptop cant keep up with the bitrate and size of the movie file.
  • joe bloe premiere
    Dec 6, 2009
    Feb 26, 2013 11:56 AM   in reply to sgribber
    I agree w/shooternz, back off the bitrate and try again.
    Feb 26, 2013 12:08 PM   in reply to sgribber
    That's unlikely.  The video industry is based around a single frame rate for any given file.  And PP itself isn't capable of exporting variable frame rates.  Bitrates, yes, but not frame rates.
    For TV viewing of that source material, I recommend the HD 1080p 23.976 preset found under the H.264 format.
    Feb 26, 2013 7:41 PM   in reply to sgribber
    What are the specs of the animated and logo clips?
    Feb 27, 2013 12:04 PM   in reply to sgribber
    Playback via my laptop using Quicktime player.
    Try the default HD preset again, but this time using VLC for playback.
    Feb 27, 2013 2:05 PM   in reply to sgribber
    It's the MB that dramatically slows things down.
    Feb 28, 2013 12:59 AM   in reply to sgribber
    You can export your timeline as an avi using a "lossless" codec like Lagarith or UT - both of these are free downloads.
    Another good possibility is to use the free Avid DNxHD codec to export as a mov file - this too is visually lossless.
    Whether any of these will give a speedy export where you have used MB you will have to see.
    Without third-party effects, I find the Avid codec is the quickest to export.
