What is the best way to import and export footage from the 5D Mark II?
Feb 26, 2013 10:37 AM
Tags: #file #problem #resolution #adobe #after #effects #pro #premiere #files #1080p #export #import #canon #student #format #render #hd #codec #quicktime #mov #source #film #footage #guidance #5d #pipeline #injest
Hello,
I've just finished shooting what I am considering to be my directorial masterpiece.  Shot it on the Canon 5D (1080p, 24fps), and the footage looks amazing.  Now I am ready to start editing and have been using premiere lately, but I have yet to figure out the proper pipeline.  I want to know the best way to retain resolution before I delve into this project.
My questions:
1)  What is the best way to start a new project and import the footage without having to render whilst editing, so as to retain all resolution and originality of the source footage?
2)  What is the best way/ codec/ format to export this same footage once editing is complete so as to retain that crisp 1080p for which the 5D is so recognized?
3)  What is the best way/ codec/ format to import and export/ render between premiere and after effects?  I am speaking mostly of vfx and color correction.  I also have some 30fps footage that I intend to slow down in AE and then import into premiere.
I know this is pretty broad, but as a solo filmmaker I really need someone's guidance.  I rarely ever finish my films with the same, crisp look as the footage.  I need pipeline help, and really appreciate it!
    Feb 26, 2013 10:54 AM   in reply to ascreenwriter
    A tutorial list in message #3 http://forums.adobe.com/message/2276578
    1-Please NOTE that the PPro CS6 screen may look a bit different (I use CS5)
    For CS5 and later, the easy way to insure that your video and your project match
    See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
    -and a FAQ on sequence setting http://forums.adobe.com/message/3804341
    2-BluRay... but I'm not sure if 1080p is supported (I don't use BluRay)
    1080p http://forums.adobe.com/thread/995191 some work, some do not
    Also, for future posts, the Information FAQ http://forums.adobe.com/message/4200840
    Also, read Metadata contained in folder http://forums.adobe.com/thread/1015001?tstart=0
    And, finally, read Bill Hunt on project setup http://forums.adobe.com/thread/919388?tstart=0
    Feb 26, 2013 11:25 AM   in reply to ascreenwriter
    ascreenwriter wrote:
    Hello,
    My questions:
    1. Follow the advice above. Also use the Media Browser to import the footage in case you have spanned media files. Import files with the Media Browser.
    2. It largely depends on what you wish to ouput to: Blu-ray, web, etc. This FAQ gives the best answer: What are the best export settings?
    3. Use the Replace with Adobe After Effects Composition function.
    Feb 26, 2013 11:54 AM   in reply to ascreenwriter
      • We accept Film prints in 16mm or 35mm format, digital video on Sony HDCAM tape and DCP.
        • For 35mm film prints, we screen 24fps in aspect ratios of 1.37, 1.66, 1.85, or 2.39.
        • We accept sound formats of mono, stereo, Dolby SR and Dolby SRD (Dolby Digital).
        • For 16mm, we accept prints in 1.37 aspect ratio with mono optical sound.
        • For Sony HDCAM tape, we accept HD 1080 format in the following frame rates: 59.94i, 23.98psf, 25p, and 50i.
        • If your video image is 4x3, 1.85, 1.66, or 2.35/2.39/Scope you must have it pillarboxed or letterboxed during the lab transfer for it to be screened without any image distortion.
        • For HDCAM sound, we require LtRt or Dolby Pro Logic compatible stereo mixed tracks on channels 1 & 2.
        • Optional: DolbyE onchannels 3 & 4 (not all theaters are equipped for DolbyE playback). DCP must be DCI compliant, keys must be open for window specified by festival, and HDCAM or 35mm backup copy must be provided in addition. DCP will only be accepted with prior approval. Please note that these specifications are subject to change each year.
    Feb 26, 2013 4:14 PM   in reply to ascreenwriter
    Just to address what might be a difference in terminology, or maybe a misconception:
    Rendering is not the same as Export, though some use either term with interchangeablity, which is not correct in PrPro.
    Rendering is a function, that creates "proxy files," just for the smoothest playback, where Export is a function of outputting the Timeline to a Video file, for either delivery, or for editing in another program.
    Rendering a Timeline will not degrade the quality of the footage, or affect the output, unless one checks "Use Rendered Files." This article goes into more detail on Rendering in Premiere: http://forums.adobe.com/message/4068277#4068277
    Now, I assume that by "rendering," you mean outputting the Timeline to a Video file. If that file is to be used as an intermediate, for additional editing, then that can degrade quality, unless one uses a lossless CODEC. This article goes into more detail on "intermediate files:" http://forums.adobe.com/message/4556586#4556586
    The best part is that you have received great, and useful advice, and I only wanted to add a few comments, basically for those, who might find the thread later on, and become afraid of Rendering (for smoothest playback).
    Feb 28, 2013 3:01 PM   in reply to ascreenwriter
    If you have to render 5D media, it's likely your system just isn't powerful enough.
