Hi Fellow BC users,
Upon trying to use the Ajax form submission method I found that it's not working as documented on the KB:
http://kb.worldsecuresystems.com/851/cpsid_85119.html
I have received confirmation from BC tech guys that this has been fixed and the KB will be updated.
I don't know what exactly was fixed/ changed but I asked BC tech guys to post an update here in the forum.
So for any of you who want's to use the Ajax/ jQuery effect please note that the KB will be updated.
Cheers
Micha
Go to demo.worldsecuresystems.com and look at the example on that site. It
works there and there are also step by step instructions on how to
implement it.
Thanks Mario,
I guess BC support don't have a clue what's going on in there messy KB pages.
Here is a screen shot of the changes in the script.
Cheers
Hi Mario
Is there a way to make this work with an Update user details form i.e. forms with action="/MemberProcess.aspx"?
I get a 400 (Bad Request) error when trying to apply this method. I have searched around adn connot find any info on this.
Tim
The JSON element is only availible for the main web form process. You can not do that the same way with other forms. ANY form though can be ajaxed.
The best thing you can do is understand jQuery Ajax:
http://api.jquery.com/jQuery.ajax/
Looking at things like dataType etc.
Thanks for the advice Liam.
Turns out I had this working previously before I found this article and added JSON=1 but it didnt appear to be doing anything.
I am attempting to update the value of a custom CRM field (checkbox list). I added a FirstName field and this updates successfully.
EDIT: Sorry I lied when I tested and changed the FirstName I was on a page I had used a webform to post the data which worked for updating all data but has the drawback of creating cases and requiring user name and email to be sent. Back to square one.
Is the problem perhaps in the data I am sending? currently created through .serialize():
FirstName=Tim&CAT_Custom_252221_90921=AtoB&CAT_Custom_252221_90921=Craft
Should this be
FirstName=Tim&CAT_Custom_252221_90921_0=AtoB&CAT_Custom_252221_90921_1=Craft
Is it preferable to send a string like above or an object?
And lastly if the success function is triggered is it safe to assume the record will be updated as the response I get is an HTML string of the page so I am not sure how to check for success like you can with a JSON response as shown in the linked KB from the OP.
Thanks alot and sorry if any of this is basic knowledge, I am entirely self taught so some things are bound to have slipped through the cracks.
Tim
There are two things to a form, POST and GET.
You can fetch data in ajax or post ajax data.
JSON is the return information - it is returned in a JSON format to process.
JSON and JSONP exist because the format is string like you can use for data transition and then convert back into an object etc
JSON response in BC only works on the web forms. Everything else will return html. So you have to handle that yourself.
Asking what your asking is not a problem, JSON only being on web forms etc is not well outline properly in the BC docs, the jQuery link on Ajax and reading through that when you can though will help you understand the core and basics of what you pass and what is returned. Once you have a good grasp of that you can use ajax in BC or elsewhere and be able to handle what comes back and what you send and what you do with it.
Thanks for you input Liam. I got it working.
My ajax function was fine the problem was the data I was posting.
For others who read this ... when updating CRM data you MUST post data for
This can be kept as it was using {module_FirstName} etc
When posting to update custom CRM fields you need to include FormID=XXXXXX (the id of your custom CRM form).
Doing a post but you understand the JSON aspect and why there is none though? That is important. And your handling failure etc?
Even though bc doesn't return json on any firm but standard webform, you
can always parse the html it returns for errors. The best method imo is to
make it in jquery object and use jquery syntax on it the way you use it in
a standard page.
True , The return html can be read through but it is important to note that be it a BC success or fail it will be an ajax success. So how you handle it is key which it what I was refering to
My understanding of JSON not being available is that BC doesn't support it as a return for this form and obviously if JSON is not returned I cannot use it.
As for handling failure. I can parse the HTML and find the vaules for the feilds I am editing or in the case of the checkbox list the output of {module_customerfield,XXXXX,XXXXXX} and confirm it matches the data sent.
Though this seems a little clunky is there a more efficent method?
Did you ever get this to work with "Update User Details" form for the CRM and Extended CRM?
Hi
http://www.weightlossmentorprogram.com.au/joinnowtest
1. I have implemented your example and when it submits the message and the form on the page is seen for a second and then it disappears. Why would this be?
2. I am trying to submit 2 forms with 1 button. The form will submit the customers details into backend of BC and then the button will take the user offsite to Paypal to pay the monthly subscripton.
Doesn't seem to be working.
Ta
