If the image is at the top left it would be easy - float: left; However if you want to place it at the bottom left like in your picture it won't be possible unless you break up the text with <p>.
Although I'm not sure if this is currently supported by browsers, there's CSS Regions you can use for this purpose:
http://dev.w3.org/csswg/css3-regions/
http://html.adobe.com/webstandards/cssregions/
Kenneth Kawamoto
Hi osgood,
Thanks for the answer.
Because I'm new in Dreamweaver the stuff is not realy clear for me.
Till now on I have made the adjustments for the layout with CSS-properties (box-size / margin / float etc.... and the name of the image I use is defined in CSS-backgrond-image).
I begin to think that my way is not 100% OK.... by reading your suggested code?
The code you write belongs in the HTML .... or not?
I get confused to do things in HTML and SCC both! Is it possible to solve this problem in CSS only ..... or am I talking "rubbish"?
Is it possible to give a hint.... what I must write in the HTML and what in the CSS.... may be you have an example?
By the way: here the yellow-box is a sub-box, and the orange-box is the entire page.
Thank you!
Include the below css in your css stylesheet or insert it along with the other css styles in the head section of your page.
Change #subBoxName to the name you have given the yellow container.
This code is for a container with and id name
#subBoxName img {
float: left;
margin-right: 12px;
margin-top: 12px;
margin-bottom: 12px;
This code is for a container with and class name
.subBoxName img {
float: left;
margin-right: 12px;
margin-top: 12px;
Thanks!
But I do something wrong! *&&^%&$$!!!!
In my case I have the image in an separate box in the yellow box-container....so the yellow box consists of 2 things... 1) the text itself and 2) the image-box with the image. Is that Ok ? or is there a better way?
In your text ... the word IMG is indeed "img" or must it be the name of my image (example: /Images/MyPicture.jpg)?
#subBoxName img {
float: left;
margin-right: 12px;
margin-top: 12px;
Do I understand well: you posted two examples.... the one above should be OK by itself?
And: I think in my case the yellow box hase the name: #Body #BodyMidden (not only 1 # in the name)
Take the image out of the image box. You don't need another box around the image. Just insert the image into the text box (the yellow box) itself, without another box wrapping the image.
Then use the name of your yellow box to replace subBoxName if its named something else.
#subBoxName img {
float: left;
margin-right: 12px;
margin-top: 12px;
maybe you search for this? Please have look here at a my rough layout: http://hansgd.de/AdobTest/TextUmfliessen/TextUmfliessenFotoLink.php.
In this form of presentation I work with borders around the text and the image (they are naturally not necessary) and a certain spacing (can be modified at will) which surrounds the text. Into the image is integrated a link.
Hans-Günter
> are YOU satisfied now
How? If you look at Fred's picture, the floating image is at the bottom of the text block. Your exapmle does not do that. (No need to wrap the image in <span> by the way.) However, you may be right, Fred didn't actually mean it - may as well, since as I said earlier it's not posible to do so with simple float: left; ![]()
Kenneth Kawamoto
Hi Hans-Günter & Kenneth Kawamoto,
Thanks for so far.
1) The example of Hans is near by...........
2) I will try to explain more .... so there's more light
on my question.
Below (first example) a screenshot of a WORD document. I can place the image anywhere in the text, the text goes always around the image.
Second example: the text goes around an image that is "rounded"
Below: the image that I was trying with in Dreamweaver. (just like the Word-document as discribed above). I want text just like above. And as you can see it has shadow around and rounded corners In the example of Hans the shadow dissapears, and it goes not around the image.
So............any suggestions ? ? ![]()
Hallo Fred,
why do you not integrate your photos created with WORD for reasons of simplicity into the DW text as I've shown you above. Adapt my design just as long as it corresponds to your ideas.
What concerns the text around the frog picture I do not have high hopes. I see only two possibilities:
InDesign allows "wrapping text around objects". See also: http://helpx.adobe.com/en/indesign/using/text-wrap.html.
As for the possibilities of export of Indesign files see
http://help.adobe.com/en_US/indesign/cs/using/WS376CC874-7325-4e1a-BDE C-D4BAE05F90F1a.html
Good luck!
Hans-Günter
Fred, what you are trying to do is called "exclusions". Here's a good explanation for it: http://galjot.si/css-exclusions
I made a quick example using your frog: http://www.materiaprima.co.uk/dev/exclusion/exclusion.html
A big caveat: the example above currently only works on Internet Explorer 10. However, I couldn't get the IE10 to understand my polygon exclusion area though, so it is kind of working but not fully
Chrome 25 currently understands exclusions (with Experimental Webkit Features flag turned on) but only for shape-inside - you'll need shape-outside for the frog to work as in my example.
In any case this is for the future. Currently you cannot do this.
Kenneth Kawamoto
Fact of the matter is, web pages are limited.
Unless we have the client download fonts, we are, essentially, limited to five. Unless we use images. All exclusions, inclusions and so on are rectangular, period. It is really hard to put a photo into the middle of a web page and have text naturally flow around it like you can do in print. photos and graphics like to be floated either left or right.
You can create boxes for image files and have text with them, but you have to declare a div (rectangle) for that.
So we cannot do a lot of the stuff that the print people can do. And there isn't (to my knowledge) a drag-and-drop WYSIWYG website editor that actually works and creates standard HTML and CSS.
But, within those limitations, we can do some pretty magnificent things.
A few comments about your website, Fred. You want to make the photos and images a little larger than what they may be on the printed page. And you do, definitely, want to break up the text. Text on the Worldwide Web is pretty low-resolution, coming in at either 72 DPI (PC. Linux, Windows) or 96DPI (Macintosh, except for Retina Display, which is higher). This causes eye fatigue.
You need to take any text block and break it up, either with photos or with other graphic elements so that you give the eye some "rest." As a result, you'll notice that people do not read your web pages, they scan them.
-Mark
As Mark said, designing for the web is nothing like desktop publishing. CSS float-left and float-right are well suited to wrapping text around images but you can't position images anywhere. They will be aligned with top of text.
http://alt-web.com/DEMOS/CSS2-Captions-on-floated-images.shtml
Using a multi-column layout is another option but your text will remain inside boxes rather than wrap around image.
http://alt-web.com/DEMOS/3-CSS-boxes.shtml
Nancy O.
Thanks for the posts
I figured something out from the website ALT-WEB.COM ... Nancy O had said.
Now I have this (below) and I am satisfied with it.
View of screenshot (part of) and code below.
I' am not sure the code is correct because of the colour of the code in my Dreamweaver-text-editor.... I suppose (e.g.) that some comment should be gray and other text should be blue ??? isn't it?
By the way: if I reply to -one- person....who gets a mail that there is an answer of me....just only that person or all persons of that discussion?
Fred
CODE................
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<link href="Css/LayOut.css" rel="stylesheet" type="text/css" />
<style type="text/css">
.floatLeft {
float: left;
width: 300px;
height: 200px;
margin: 10px;
margin-top: 8px;
margin-bottom: 7px;
margin-left: 0px;
.floatLeft p {
margin-top: 0px;
/**border around image**/
.floatLeft img {
border-radius: 8px;
#BodyMid {
width: 600px;
clear: both;
margin-right: auto;
margin-left: auto;
</style>
</head>
<div id="Body">
<div id="BodyLeft"></div>
<!- End body Left->
<div id="BodyMid"><!- Begin body Mid->
<div class="floatLeft"><!-Begin floatleft->
<p><img src="Images/wegtest.jpg" width="300 height="200" /></p>
</div>
<!-end floatleft->
<p>Amet iusto cum ex veniam me, anteposuerit commodo et at. Facit sollemnes saepius non lectores Non, per elit, nunc suscipit fiant enim at. Euismod consuetudium videntur ad hendrerit eodem adipiscing laoreet cum claritas, etiam.</p>
<p>Lorem ipsum dolor sit amet, eodem eleifend ad consuetudium humanitatis formas. Adipiscing est nulla in nihil nibh id. Claram processus hendrerit eorum ii investigationes Iriure molestie dynamicus, erat decima. Videntur consequat legunt te odio assum iusto me est. Non, per elit, nunc suscipit fiant enim at. nobis lius per. Iriure molestie dynamicus, erat decima. Videntur consequat legunt te odio assum iusto me est. Non, per elit, nunc suscipit fiant enim at. Iriure molestie dynamicus, erat decima. Videntur consequat legunt te odio assum iusto me est. Non, per elit, nunc suscipit fiant enim at. Euismod consuetudium videntur ad hendrerit eodem adipiscing laoreet cum claritas, etiam.</p>
</div>
<!- end body Mid->
</div>
<!- end body->
</html>
CODE END..................
below the screenshot (colours ???)
Hello Fred, hello all,
at the suggestion of kennethkawamoto2 about "exclusions" I've been searching and working a little bit more. To get straight to the point: We all will have interesting possibilities to future projects AND/BUT we have to wait 'till the most of us (and esp. our visitors) can use IE 10.
Here is another link (thanks to Paula) http://msdn.microsoft.com/en-us/library/ie/hh673558.aspx, where Microsoft shows some topics about "exclusions". On the basis of that I made a real formless draft, only to see what's possible. You can find it - using IE 10 - here: http://hansgd.de/AdobTest/TextUmfliessenCSS/TextUmfliessenCSSWINOrig.p hp.
And again Paula: "If you, or anyone else wishes to vote for support of many of these ’new’ css3 features ..." (Hans is continuing) use https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform.
Hans-Günter
Hallo All,
Ok thanks for so far.....I can go further.
BTW. my colour-problem in code is solved.... Nancy said use double - hyphen in comments.... that was 1 solution.
The other was a forgotten " (double quote) after the width declaration of my image ("300 ).
Say:.....all begining is difficult ![]()
North America
Asia Pacific
