The Media Queries dialog box is not showing the properties to allow me to edit. The heading for properties is showing however no information is being displayed. Does anyone know what is causing this. I am using windows 7 on a netbook.
I saw another post from you via Community Help. I guess you're referring to this?
If you are, then you have to create a new Media Query parameter first. Or you could also use 'Default Presets'. Clicking on Default Presets will create 3 presets (phone, tablet & Desktop) and will allow you to customize their properties like this:
If you're an advanced user and want to start from scratch, you can click on the '+' sign instead of 'Default presets' to start defining your own properties. You can create as many properties as you would like, as follows:
Trust this helps.
-ST
If you're on Windows, follow instructions here: http://graphicssoft.about.com/cs/general/ht/winscreenshot.htm to take a screenshot.
If you're on Mac, press Cmd + Shift + 4, drag an area that you want to screenshot. The image will be stored on your Desktop.
Upload that image here using the little 'Camera' icon on the top when you press 'Reply'.
Can you try clearing your cache: http://forums.adobe.com/thread/494811
If deleting the MacFileCache-***.dat alone doesn't help, read the steps in the URL above to delete the containing folder.
Not to worry - this is not destructive. DW will re-create it on next start.
This is the problem being faced by me, too. Here is the screenshot.
You can see that there is absolutely no way in which I can get access to the supposedly present css file button on the properties panel. I tried your solution of removing the .Dat file but no go.Please help.
This is a new html file and not a template.
You're right. The media query panel is too long to fit my display. So I can't access the lower input fields at all. Shows how often I use this panel - never.
File a Bug Report
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Nancy O.
Lucky you! But I alas, need to attach media query css files ever so often because my clients want responsive websites which can be accessed through any media regardless of screen size.
So naturally Murphy's law has made certain that I have the property panel missing in my particular software. On par with the idiosyncracies of my software model.
Anyway I've filed a bug report, that's that, nobody will bother doing anything about it and here I am left with egg on my face.
Ah well. Just the way the cookie crumbles and I mustn't grumble!
North America
Asia Pacific
