camera raw
Feb 27, 2013 5:44 PM
Cannot open camera raw in windows cs4 using cannon xsi
thanks
    Feb 27, 2013 6:49 PM   in reply to sparky 123
    Is this a EOS Digital Rebel XSi?  If so you should be able to open images with CS4 as you only need ACR 4.4 or above.
    Did it work before?
    Feb 28, 2013 12:17 AM   in reply to sparky 123
    As Curt says, you need Camera Raw 4.4 minimum to open the XSi's raw files, and as Camera Raw 5.x should be installed with CS4 you should not need to update. When you say "cannot open" what exactly do you mean? Do you get an error message? Does nothing happen? Please be more descriptive.
  • Omke Oudeman
    Nov 27, 2004
    Feb 28, 2013 8:15 AM   in reply to sparky 123
    It says error cannot recognize files!
    This usually means you have a newer RAW file format then the Raw converter in Camera Raw. But for further investigation we do need to have more details about what file you are trying to open (from which dSLR) and what version of Bridge you are using. Also in PS check About plug in to see which version of ACR you are using.
    And you are aware of the fact that all contact details are send from your iPhone with this mail? You can delete it during a short period using edit if you wish so.
  • Omke Oudeman
    Nov 27, 2004
    Feb 28, 2013 8:27 AM   in reply to sparky 123
    was not aware. How do youy delete info
    Visit the forum website, sign in and use edit
    Feb 28, 2013 2:40 PM   in reply to Omke Oudeman
    You probably can not edit info if the post has been responded to.  Will have to wait for a Moderator to come in and wipe personal info. [done -- if you flag a message for review, it'll be attended to pretty quickly ]
    Most problems with camera raw are either you have wrong ACR version, it is in wrong folder, or there are 2 versions in the folder.
    If you open a picture camera raw (even right click for jpeg) in Bridge look at the version number in upper left hand corner of window.  What is that?
    Feb 28, 2013 11:46 AM   in reply to sparky 123
    If you download the Adobe DNG convertor you achieve two things
    1. You can save 20% of file space as DNG RAW files are compressed, but without losing any of their funcionality
    2. It doesn't matter what camera you have, as you will always be able to read the DNG files.
    http://www.adobe.com/support/downloads/product.jsp?product=106&platfor m=Windows
