CS5 losing levels ajustment
Feb 27, 2013 9:50 PM
I am losing my levels adjustment when converting from PSD to any other format here is the jist of it...
levels layer...........taking the contrast way up
saturation layer....saturation up
invert function
find edges layer
duplicate layer
background layer
At the point that I convert to jpg or another file type I lose the levels adjustment.
Also flatten image or merge visible layers causes the same problem.
I can supply a file if needed
Any ideas???
Thanks in advance
Mike
    Feb 27, 2013 11:32 PM   in reply to mikearend
    I think you are another victim of the popular assumption that Photoshop’s preview at anything other than 100% is reliable.
    In many/most cases this is irrelevant but with especially noisy/contrasty images for example this can make a huge difference.
    So please use View > 100% on the layered File then flatten – does the appearance change?
    Ina any case: Would you mind posting some screenshots?
    Feb 28, 2013 5:17 AM   in reply to mikearend
    In Photoshop preview sizes other than Actual Pixels for a layered image can entail interpolated Layers and Masks which can affect the preview.
    Mar 1, 2013 5:09 AM   in reply to mikearend
    Over at
    http://forums.adobe.com/thread/1162434?tstart=0
    conroy points out that setting a Cache Level of 1 in the Performance Preferences would alleviate the issue.
    (But this could have performance drawbacks depending on the images you work on.)
    Mar 1, 2013 5:22 AM   in reply to c.pfaffenbichler
    Christoph, no, the particular colour distortion you showed is not prevented by Cache Levels 1.
    Mar 1, 2013 5:26 AM   in reply to conroy
    With the pure black/white noise image and the Curves Layer it seems to remove the color cast, though.
    Mar 1, 2013 5:32 AM   in reply to c.pfaffenbichler
    That's good. Cache Levels 1 is more effective than I thought, then.
    I still got the colour cast of your example, but my graphics card and driver (supplied by Apple) are quite old and do have problems with 16-bit mode when Cache Levels is 1.
    Mar 1, 2013 5:34 AM   in reply to conroy
    And a relaunch of Ps is now resulting in the colour cast not being evident in 8-bit mode. Cache Levels 1 definitely is more useful than I thought.
    Mar 1, 2013 5:37 AM   in reply to conroy
    So I learned something new today.
    Mar 1, 2013 6:07 AM   in reply to c.pfaffenbichler
    I was under the impression that a change of Cache Levels would affect subsequently opened/created documents without a relaunch of Ps. That's not the case for me (today, at least). A relaunch of Ps is necessary to affect a change on my computer. Now the colour cast does not occur in both 8-bit and 16-bit modes.
