P343W
Transfert projets DE CS5 vers CS6
Feb 28, 2013 2:04 AM
Tags: #premiere #bug #mxf #project
J'ai un projet en cours de 1h30 avec divers formats de fichiers et utilisation de séquences imbriquées en multi-camera.
Je souhaite continuer ce projet sous CS6, mais le transfert ne s'effectue pas correctement.
Une piste qui contient des fichiers .mxf, n'est pas correctepment chargée. Au lieu d'avoir des contenus différents sur les Mxf 1, 2 3 ..., j'ai toujours le contenu de Mxf 1. Si je tente de reimporter le bon fichier, il me donne toujours le contenu de mxf 1 !!
Bien entendu, sur un projet vierge CS6 ou une conformation en CS5 tout est OK.
Pouvez-vous me donner une exolication et une solution ?
al.bertaux@orange.fr
    Feb 28, 2013 2:19 AM   in reply to P343W
    This is a English spoken forum. Please write your postings in English or post it in the French forum (http://forums.adobe.com/community/international_forums/francais)
    Thanks.
    Axel
    Mar 2, 2013 2:27 AM   in reply to P343W
    I don't have any experience with multi-cam editing. Normally is not a problem to continue editing CS5 projects in CS6. But it is possible that Adobe  has made some changes betwenn CS5 and CS6.
    I have heard many times that is the preferred method is to edit existing CS5-projects in CS5. New projects can be started then in CS6.
    Axel
    Mar 2, 2013 5:57 AM   in reply to P343W
    Try creating a new project in CS6, then *import* the old CS5 project into the new one.
    Jeff
    Mar 5, 2013 12:16 AM   in reply to P343W
    I mean it so how I wrote it.
    All projects that you have created under version CS5 has to been finished in CS5. All new project that you'll started can be created in CS6
    Axel
    Mar 5, 2013 5:18 AM   in reply to P343W
    Try this:
    After you import the CS5 project into the new CS6 project, make all of your media offline.  Save and close the project.
    Move the media to a different location -- different folder, different hard drive, anything.
    Launch Pr and open your project again, then relink your media.
    Jeff
    Mar 5, 2013 5:43 PM   in reply to P343W
    Essaie ce que Jeff Bellune préconise plus haut.
    Please try Jeff's suggestions and report back.
