Workflow for many sequences
Feb 28, 2013 3:37 AM
Tags: #clips #titles #sequences
Hello,
I am making many (100+) short educational movies. They are of four different categories, each has its "design", that is the background is similar, titles are the same and the content is in the same order.
Some of the titles and clips are also shared between the movies in the different categories.
Now I put all sequenses in one project, I just wanted to check with you pros, if this is the best way of handling a project like this?
Also - if I have let say 1 min part of a clip in a sequence, and want to use that clip (with titles and everything) once again in that sequence - is there a more simple way of handeling this, than - as I do now - cutting out the part, copy the part, and pasting it where I want the "replay" to be?
Thanks in advance,
Håkan
  • joe bloe premiere
    Dec 6, 2009
    Feb 28, 2013 5:53 AM   in reply to HakanErn
    Now I put all sequenses in one project, is this is the best way of handling a project like this?
    Absolutely... that's what Premiere is built to do.
    ...is there a more simple way of handeling this, than - as I do now - cutting out the part, copy the part, and pasting it where I want the "replay" to be?
    You can lasso select the clip(s) in the timeline you want
    to duplicate (video and/or audio), then Alt-Drag the
    selected clips to duplicate them within your sequence.
  • joe bloe premiere
    Dec 6, 2009
    Feb 28, 2013 6:24 AM   in reply to HakanErn
    To lasso-select clips in your timeline, left-click with the selection tool
    and drag a boundary box around the clips you want.
