Flash CS6 crashes all the time
Feb 28, 2013 7:16 AM
Tags: #java #flash #crash #cs6
Hi All,
I'm having a really big problem with my flash, every time I try to work on a document the software crashes.
It doesn't matter if I'm working on a video, bitmap, text, if I try to open the action panel or try to do anything ir crashes.
I'm running Flash CS6 on Mac OS 10.6.8 with an 3.06 Intel i3 Processor and 4Gb of memory.
If it helps I'll paste my error message down below.
[code]
Process:         Adobe Flash CS6 [3413]
Path:            /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
Identifier:      com.adobe.flash
Version:         12.0.0.481 (12.0.0)
Code Type:       X86 (Native)
Parent Process:  launchd [117]
Date/Time:       2013-02-28 12:00:16.684 -0300
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Interval Since Last Report:          194920 sec
Per-App Interval Since Last Report:  86615 sec
Per-App Crashes Since Last Report:   15
Anonymous UUID:                      65E38CDA-CB40-4103-BC8D-XXXXX
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000bf7f2eec
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=00000000011f5916
Java VM: Java HotSpot(TM) Client VM (20.14-b01-445 mixed mode macosx-x86)
Current thread (000000003c000800):  JavaThread "main" [_thread_in_native, id=-1603754688, stack(00000000bf800000,00000000c0000000)]
Stack: [00000000bf800000,00000000c0000000]
Java Threads: ( => current thread )
  000000003f039400 JavaThread "Thread-4" [_thread_blocked, id=-1314734080, stack(00000000b192c000,00000000b1a2c000)]
  000000003f05f000 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1306181632, stack(00000000b2154000,00000000b2254000)]
  000000003f05e800 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1307238400, stack(00000000b2052000,00000000b2152000)]
  000000003b978c00 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1308295168, stack(00000000b1f50000,00000000b2050000)]
  000000003b978400 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1309351936, stack(00000000b1e4e000,00000000b1f4e000)]
  000000003f04e400 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1310408704, stack(00000000b1d4c000,00000000b1e4c000)]
  000000003b919400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1312522240, stack(00000000b1b48000,00000000b1c48000)]
  000000003b918400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1315790848, stack(00000000b182a000,00000000b192a000)]
  000000003b917400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1316847616, stack(00000000b1728000,00000000b1828000)]
  000000003b916400 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1317904384, stack(00000000b1626000,00000000b1726000)]
  000000003b90a000 JavaThread "Finalizer" daemon [_thread_blocked, id=-1318961152, stack(00000000b1524000,00000000b1624000)]
  000000003b909000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1323438080, stack(00000000b10df000,00000000b11df000)]
=>000000003c000800 JavaThread "main" [_thread_in_native, id=-1603754688, stack(00000000bf800000,00000000c0000000)]
Other Threads:
  000000003b906800 VMThread [stack: 00000000b0cff000,00000000b0dff000] [id=-1327501312]
  000000003b91ac00 WatcherThread [stack: 00000000b1c4a000,00000000b1d4a000] [id=-1311465472]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation   total 14784K, used 8305K [0000000040110000, 0000000041110000, 0000000041110000)
  eden space 13184K,  50% used [0000000040110000, 000000004079c4e8, 0000000040df0000)
  from space 1600K, 100% used [0000000040f80000, 0000000041110000, 0000000041110000)
  to   space 1600K,   0% used [0000000040df0000, 0000000040df0000, 0000000040f80000)
concurrent mark-sweep generation total 49152K, used 10671K [0000000041110000, 0000000044110000, 0000000048110000)
concurrent-mark-sweep perm gen total 12288K, used 8403K [0000000048110000, 0000000048d10000, 000000004c110000)
Code Cache  [000000003c801000, 000000003c93a000, 000000003e801000)
total_blobs=691 nmethods=561 adapters=73 free_code_cache=32284480 largest_free_block=384
Virtual Machine Arguments:
JVM Args: -Djava.awt.headless=true -Xmx128m
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 4096M, Free = 1088M
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
0   com.adobe.flash                         0x011f5916 FMap<int, int, AsScope*, AsScope*>::operator[](int) + 33644
1   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
2   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
3   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
4   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
5   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
6   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
7   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
8   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
9   com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
10  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
11  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
12  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
13  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
14  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
15  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
16  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
17  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
18  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
19  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
20  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
21  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
22  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
23  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
24  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
25  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
26  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
27  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
28  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
29  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
30  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
31  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
32  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
33  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
34  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
35  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
36  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
37  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
38  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
39  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
40  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
41  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
42  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
43  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
44  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
45  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
46  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
47  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
48  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
49  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
50  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
51  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
52  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
53  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
54  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
55  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
56  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
57  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
58  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
59  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
60  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
61  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
62  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
63  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
64  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
65  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
66  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
67  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
68  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
69  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
70  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
71  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
72  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
73  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
74  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
75  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
76  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
77  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
78  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
79  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
80  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
81  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
82  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
83  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
84  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
85  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
86  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
87  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
88  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
89  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
90  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
91  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
92  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
93  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
94  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
95  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
96  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
97  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
98  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
99  com.adobe.flash                         0x011f602e FMap<int, int, AsScope*, AsScope*>::operator[](int) + 35460
100 com.adobe.flash                         0x008f726a CURI::~CURI() + 23014
101 com.adobe.flash                         0x008ba94e CBitmapComboBox::GetRuntimeClass() const + 58700
102 com.adobe.flash                         0x00e124cb std::basic_ostream<unsigned short, std::char_traits<unsigned short> >& std::__ostream_insert<unsigned short, std::char_traits<unsigned short> >(std::basic_ostream<unsigned short, std::char_traits<unsigned short> >&, unsigned short const*, int) + 29997
103 com.adobe.flash                         0x00e135d2 std::basic_ostream<unsigned short, std::char_traits<unsigned short> >& std::__ostream_insert<unsigned short, std::char_traits<unsigned short> >(std::basic_ostream<unsigned short, std::char_traits<unsigned short> >&, unsigned short const*, int) + 34356
104 com.adobe.flash                         0x0026e1da MFIVideoModuleDefinition::~MFIVideoModuleDefinition() + 18876
105 com.adobe.flash                         0x0027f041 MFIVideoModuleDefinition::~MFIVideoModuleDefinition() + 88099
106 com.adobe.flash                         0x00684911 CMiniDockFrameWnd::~CMiniDockFrameWnd() + 901
107 com.adobe.flash                         0x002792f1 MFIVideoModuleDefinition::~MFIVideoModuleDefinition() + 64211
108 com.adobe.flash                         0x0116f556 TEventHandler<MMUI::PanelParentWndForMac>::~TEventHandler() + 2234
109 com.adobe.flash                         0x0116dbcb std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, std::allocator<std::pair<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >::operator[](std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 5855
110 com.adobe.flash                         0x0116f940 TEventHandler<MMUI::PanelParentWndForMac>::~TEventHandler() + 3236
111 com.apple.HIToolbox                     0x98b4cc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
112 com.apple.HIToolbox                     0x98b4bef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
113 com.apple.HIToolbox                     0x98b4bd55 SendEventToEventTargetWithOptions + 58
114 com.adobe.owl                           0x084848f1 OWLThemeChangeColorDefinition + 702
115 com.adobe.owl                           0x08485fc9 OWLThemeChangeColorDefinition + 6550
116 com.adobe.owl                           0x085251d0 OWLDebugPrintOSXWindowHierarchy + 13148
117 com.adobe.owl                           0x0852524d OWLDebugPrintOSXWindowHierarchy + 13273
118 com.adobe.owl                           0x084bdef7 OWLPaletteCreateNonComposite + 144218
119 com.adobe.owl                           0x0849d4f6 OWLPaletteCreateNonComposite + 10585
120 com.adobe.owl                           0x0848b91e OWLThemeChangeColorDefinition + 29419
121 com.adobe.owl                           0x084ade46 OWLPaletteCreateNonComposite + 78505
122 com.adobe.owl                           0x0849d72c OWLPaletteCreateNonComposite + 11151
123 com.adobe.owl                           0x0848bc97 OWLThemeChangeColorDefinition + 30308
124 com.adobe.owl                           0x0849b01b OWLPaletteCreateNonComposite + 1150
125 com.adobe.owl                           0x084ad083 OWLPaletteCreateNonComposite + 74982
126 com.adobe.owl                           0x084a1c14 OWLPaletteCreateNonComposite + 28791
127 com.adobe.owl                           0x0849423f OWLThemeChangeColorDefinition + 64524
128 com.adobe.owl                           0x084ade46 OWLPaletteCreateNonComposite + 78505
129 com.adobe.owl                           0x0849f2e1 OWLPaletteCreateNonComposite + 18244
130 com.adobe.owl                           0x0849b01b OWLPaletteCreateNonComposite + 1150
131 com.adobe.owl                           0x084ad083 OWLPaletteCreateNonComposite + 74982
132 com.adobe.owl                           0x084d9051 OWLTabGroupChangeHideTabwellWithSingleTabItem + 5563
133 com.adobe.owl                           0x084e1a99 OWLTabGroupChangeHideTabwellWithSingleTabItem + 40963
134 com.adobe.owl                           0x084ade46 OWLPaletteCreateNonComposite + 78505
135 com.adobe.owl                           0x084db750 OWLTabGroupChangeHideTabwellWithSingleTabItem + 15546
136 com.adobe.owl                           0x084e0951 OWLTabGroupChangeHideTabwellWithSingleTabItem + 36539
137 com.adobe.owl                           0x0849b01b OWLPaletteCreateNonComposite + 1150
138 com.adobe.owl                           0x084ad083 OWLPaletteCreateNonComposite + 74982
139 com.adobe.owl                           0x084f2178 OWLDockGetContent + 50173
140 com.adobe.owl                           0x084b840e OWLPaletteCreateNonComposite + 120945
141 com.adobe.owl                           0x084bae65 OWLPaletteCreateNonComposite + 131784
142 com.adobe.owl                           0x085465fd OWLDocumentCreateNonComposite + 29114
143 com.adobe.owl                           0x08557af9 OWLWorkspaceBookmarkSnapshot + 19626
144 com.adobe.owl                           0x0849a8df OWLPaletteGetSize + 320
145 com.adobe.owl                           0x08499e10 OWLPaletteCreate + 795
146 com.adobe.owl                           0x08499fb2 OWLPaletteShow + 24
147 com.adobe.flash                         0x0115b167 CTypedPtrArray<CPtrArray, MMUI::PanelSpecificStateInfo*>::~CTypedPtrArray() + 29845
148 com.adobe.flash                         0x0115b214 CTypedPtrArray<CPtrArray, MMUI::PanelSpecificStateInfo*>::~CTypedPtrArray() + 30018
149 com.adobe.flash                         0x00364b23 std::deque<CSketchSWFHistory, std::allocator<CSketchSWFHistory> >::resize(unsigned long, CSketchSWFHistory) + 28575
150 com.adobe.flash                         0x00f95347 CMiniFrameWnd::~CMiniFrameWnd() + 863
151 com.adobe.flash                         0x00fc3fa4 CPropertyPage::GetRuntimeClass() const + 9792
152 com.adobe.flash                         0x00f71b21 CButtonImplBase::~CButtonImplBase() + 8129
153 com.adobe.flash                         0x00fd933a TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 17124
154 com.adobe.flash                         0x00fda65e TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 22024
155 com.adobe.flash                         0x00fd5bc6 TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 2928
156 com.adobe.flash                         0x001feb01 CArray<CTimer*, CTimer*>::~CArray() + 11005
157 com.adobe.flash                         0x0117277c CList<MMUI::DocumentFrame*, MMUI::DocumentFrame*>::RemoveAt(__POSITION*) + 3866
158 com.adobe.flash                         0x00fda65e TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 22024
159 com.adobe.flash                         0x0030ca19 CTemporaryMenu::~CTemporaryMenu() + 1117
160 com.adobe.flash                         0x00fd5bc6 TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 2928
161 com.adobe.flash                         0x001feb01 CArray<CTimer*, CTimer*>::~CArray() + 11005
162 com.adobe.flash                         0x00fc3d22 CPropertyPage::GetRuntimeClass() const + 9150
163 com.adobe.flash                         0x010632b8 cf_bad_change::~cf_bad_change() + 3550
164 com.apple.HIToolbox                     0x98b4cc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
165 com.apple.HIToolbox                     0x98b4bef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
166 com.apple.HIToolbox                     0x98b6e7f3 SendEventToEventTarget + 52
167 com.apple.HIToolbox                     0x98b9ae87 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
168 com.apple.HIToolbox                     0x98bbfb90 SendMenuCommandWithContextAndModifiers + 66
169 com.apple.HIToolbox                     0x98bbfb47 SendMenuItemSelectedEvent + 121
170 com.apple.HIToolbox                     0x98bbfa5d FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
171 com.apple.HIToolbox                     0x98b8f160 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
172 com.apple.HIToolbox                     0x98d41936 MenuSelect + 190
173 com.apple.HIToolbox                     0x98cfa8e0 HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 92
174 com.apple.HIToolbox                     0x98b4d22b HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 173
175 com.apple.HIToolbox                     0x98b4cc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
176 com.apple.HIToolbox                     0x98b4bef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
177 com.apple.HIToolbox                     0x98b6e7f3 SendEventToEventTarget + 52
178 com.apple.HIToolbox                     0x98b803ef ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1417
179 com.apple.HIToolbox                     0x98b4d080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
180 com.apple.HIToolbox                     0x98b4bef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
181 com.apple.HIToolbox                     0x98b6e7f3 SendEventToEventTarget + 52
182 com.apple.HIToolbox                     0x98cf7c17 ToolboxEventDispatcher + 86
183 com.apple.HIToolbox                     0x98cf7d4f RunApplicationEventLoop + 243
184 com.adobe.flash                         0x00fcc1fb CArray<MACFTYPES*, MACFTYPES*>::SetSize(int, int) + 5271
185 com.adobe.flash                         0x00fa4c1d CTimerImpl::~CTimerImpl() + 1293
186 com.adobe.flash                         0x00fa4e00 CTimerImpl::~CTimerImpl() + 1776
187 com.adobe.flash                         0x0020fc4d std::vector<Symmetry*, std::allocator<Symmetry*> >::vector(std::allocator<Symmetry*> const&) + 6295
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib                       0x94b6b382 kevent + 10
1   libSystem.B.dylib                       0x94b6ba9c _dispatch_mgr_invoke + 215
2   libSystem.B.dylib                       0x94b6af59 _dispatch_queue_invoke + 163
3   libSystem.B.dylib                       0x94b6acfe _dispatch_worker_thread2 + 240
4   libSystem.B.dylib                       0x94b6a781 _pthread_wqthread + 390
5   libSystem.B.dylib                       0x94b6a5c6 start_wqthread + 30
Thread 2:
0   libSystem.B.dylib                       0x94b72aa2 __semwait_signal + 10
1   libSystem.B.dylib                       0x94b7275e _pthread_cond_wait + 1191
2   libSystem.B.dylib                       0x94b743f8 pthread_cond_wait$UNIX2003 + 73
3   ...ple.CoreServices.CarbonCore          0x9887f21e TSWaitOnCondition + 126
4   ...ple.CoreServices.CarbonCore          0x9886ab68 TSWaitOnConditionTimedRelative + 202
5   ...ple.CoreServices.CarbonCore          0x98866533 MPWaitOnQueue + 250
6   com.adobe.ACE                           0x069b0a69 0x6971000 + 260713
7   com.adobe.ACE                           0x069afd99 0x6971000 + 257433
8   ...ple.CoreServices.CarbonCore          0x9884a54a PrivateMPEntryPoint + 68
9   libSystem.B.dylib                       0x94b72259 _pthread_start + 345
10  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 3:
Thread 4:
Thread 5:
3   com.adobe.AFlame                        0x0bb90439 Flame_Terminate + 1281926
4   com.adobe.AFlame                        0x0bbda950 Flame_Terminate + 1586333
5   com.adobe.AFlame                        0x0bb8ea35 Flame_Terminate + 1275266
6   libSystem.B.dylib                       0x94b72259 _pthread_start + 345
7   libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 6:
0   libSystem.B.dylib                       0x94b44afa mach_msg_trap + 10
1   libSystem.B.dylib                       0x94b45267 mach_msg + 68
2   com.apple.CoreFoundation                0x9a3212df __CFRunLoopRun + 2079
3   com.apple.CoreFoundation                0x9a3203c4 CFRunLoopRunSpecific + 452
4   com.apple.CoreFoundation                0x9a3201f1 CFRunLoopRunInMode + 97
5   com.apple.Foundation                    0x915f4224 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6   com.apple.Foundation                    0x915bb4c4 -[NSThread main] + 45
7   com.apple.Foundation                    0x915bb474 __NSThread__main__ + 1499
8   libSystem.B.dylib                       0x94b72259 _pthread_start + 345
9   libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 7:
0   libSystem.B.dylib                       0x94b820d6 recvfrom$UNIX2003 + 10
1   libSystem.B.dylib                       0x94ba1eab recv$UNIX2003 + 54
2   ServiceManager-Launcher.dylib           0x25301733 Invoke + 47867
3   ServiceManager-Launcher.dylib           0x25300846 Invoke + 44046
4   ServiceManager-Launcher.dylib           0x252ff988 Invoke + 40272
5   ServiceManager-Launcher.dylib           0x252ffa0f Invoke + 40407
6   ServiceManager-Launcher.dylib           0x252fabaf Invoke + 20343
7   ServiceManager-Launcher.dylib           0x252faea7 Invoke + 21103
8   ServiceManager-Launcher.dylib           0x252fb685 Invoke + 23117
9   ServiceManager-Launcher.dylib           0x252fb8f9 Invoke + 23745
10  ServiceManager-Launcher.dylib           0x252fe2a0 Invoke + 34408
11  ServiceManager-Launcher.dylib           0x252fe3fd Invoke + 34757
12  ServiceManager-Launcher.dylib           0x252fec91 Invoke + 36953
13  ServiceManager-Launcher.dylib           0x252fedb2 Invoke + 37242
14  ServiceManager-Launcher.dylib           0x252f1656 Login + 461
15  ServiceManager-Launcher.dylib           0x252f509a Login + 15377
16  ServiceManager-Launcher.dylib           0x252ff165 Invoke + 38189
17  ServiceManager-Launcher.dylib           0x253012eb Invoke + 46771
18  libSystem.B.dylib                       0x94b72259 _pthread_start + 345
19  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 8:
0   libSystem.B.dylib                       0x94b6a412 __workq_kernreturn + 10
1   libSystem.B.dylib                       0x94b6a9a8 _pthread_wqthread + 941
2   libSystem.B.dylib                       0x94b6a5c6 start_wqthread + 30
Thread 9:  Java: Exception Handler Thread
2   libSystem.B.dylib                       0x94bb0c78 mach_msg_server + 520
3   libjvm.dylib                            0x2df0fcd0 jio_snprintf + 45191
4   libjvm.dylib                            0x2df0fb57 jio_snprintf + 44814
5   libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
Thread 10:  Java: Gang worker#0 (Parallel GC Threads)
2   libjvm.dylib                            0x2df0ed3a jio_snprintf + 41201
3   libjvm.dylib                            0x2df0ec76 jio_snprintf + 41005
4   libjvm.dylib                            0x2df0eb3c jio_snprintf + 40691
5   libjvm.dylib                            0x2df0e681 jio_snprintf + 39480
6   libjvm.dylib                            0x2df0e50b jio_snprintf + 39106
7   libjvm.dylib                            0x2df26065 jio_vsnprintf + 405
8   libjvm.dylib                            0x2df25f4f jio_vsnprintf + 127
9   libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
10  libSystem.B.dylib                       0x94b72259 _pthread_start + 345
11  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 11:  Java: Gang worker#1 (Parallel GC Threads)
Thread 12:  Java: Gang worker#2 (Parallel GC Threads)
Thread 13:  Java: Gang worker#3 (Parallel GC Threads)
Thread 14:  Java: Concurrent Mark-Sweep GC Thread
2   libjvm.dylib                            0x2df0ee0a jio_snprintf + 41409
3   libjvm.dylib                            0x2df2c9ca jio_vsnprintf + 27386
4   libjvm.dylib                            0x2df0eb58 jio_snprintf + 40719
7   libjvm.dylib                            0x2e038241 JVM_GetMethodIxExceptionTableEntry + 2242
8   libjvm.dylib                            0x2e0381af JVM_GetMethodIxExceptionTableEntry + 2096
9   libjvm.dylib                            0x2df2c7e5 jio_vsnprintf + 26901
10  libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
11  libSystem.B.dylib                       0x94b72259 _pthread_start + 345
12  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 15:  Java: VM Thread
7   libjvm.dylib                            0x2dfa6eb6 JVM_Lseek + 200687
8   libjvm.dylib                            0x2dfa6b5f JVM_Lseek + 199832
Thread 16:  Java: Reference Handler
4   libjvm.dylib                            0x2dfb5a90 JVM_MonitorWait + 3799
5   libjvm.dylib                            0x2dfb4f92 JVM_MonitorWait + 985
6   libjvm.dylib                            0x2dfb4c84 JVM_MonitorWait + 203
7   libjvmlinkage.dylib                     0x260c9e75 JVM_MonitorWait + 69
8   ???                                     0x3c80b9d9 0 + 1015069145
9   ???                                     0x3c803e31 0 + 1015037489
10  ???                                     0x3c803e31 0 + 1015037489
11  ???                                     0x3c801374 0 + 1015026548
12  libjvm.dylib                            0x2dfa81ef JVM_Lseek + 205608
13  libjvm.dylib                            0x2dfa7f63 JVM_Lseek + 204956
14  libjvm.dylib                            0x2dfb4935 JVM_StartThread + 3022
15  libjvm.dylib                            0x2dfb47c5 JVM_StartThread + 2654
16  libjvm.dylib                            0x2dfb4743 JVM_StartThread + 2524
17  libjvm.dylib                            0x2dfb459d JVM_StartThread + 2102
18  libjvm.dylib                            0x2dfb43db JVM_StartThread + 1652
19  libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
20  libSystem.B.dylib                       0x94b72259 _pthread_start + 345
21  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 17:  Java: Finalizer
10  ???                                     0x3c803f97 0 + 1015037847
11  ???                                     0x3c803f97 0 + 1015037847
12  ???                                     0x3c801374 0 + 1015026548
13  libjvm.dylib                            0x2dfa81ef JVM_Lseek + 205608
14  libjvm.dylib                            0x2dfa7f63 JVM_Lseek + 204956
15  libjvm.dylib                            0x2dfb4935 JVM_StartThread + 3022
16  libjvm.dylib                            0x2dfb47c5 JVM_StartThread + 2654
17  libjvm.dylib                            0x2dfb4743 JVM_StartThread + 2524
18  libjvm.dylib                            0x2dfb459d JVM_StartThread + 2102
19  libjvm.dylib                            0x2dfb43db JVM_StartThread + 1652
20  libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
21  libSystem.B.dylib                       0x94b72259 _pthread_start + 345
22  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 18:  Java: Surrogate Locker Thread (Concurrent GC)
6   libjvm.dylib                            0x2df0e44e jio_snprintf + 38917
7   libjvm.dylib                            0x2dfc6230 JVM_IsPrimitiveClass + 3268
8   libjvm.dylib                            0x2dfc6174 JVM_IsPrimitiveClass + 3080
9   libjvm.dylib                            0x2dfb459d JVM_StartThread + 2102
10  libjvm.dylib                            0x2dfb43db JVM_StartThread + 1652
11  libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
12  libSystem.B.dylib                       0x94b72259 _pthread_start + 345
13  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 19:  Java: Signal Dispatcher
0   libSystem.B.dylib                       0x94b44b36 semaphore_wait_trap + 10
1   libjvm.dylib                            0x2dfc6b16 JVM_IsPrimitiveClass + 5546
2   libjvm.dylib                            0x2dfc64f4 JVM_IsPrimitiveClass + 3976
3   libjvm.dylib                            0x2dfb459d JVM_StartThread + 2102
4   libjvm.dylib                            0x2dfb43db JVM_StartThread + 1652
Thread 20:  Java: C1 CompilerThread0
7   libjvm.dylib                            0x2dfce3ca JVM_Write + 426
8   libjvm.dylib                            0x2dfc7cec JVM_IsPrimitiveClass + 10112
9   libjvm.dylib                            0x2dfc7a96 JVM_IsPrimitiveClass + 9514
10  libjvm.dylib                            0x2dfb459d JVM_StartThread + 2102
11  libjvm.dylib                            0x2dfb43db JVM_StartThread + 1652
12  libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
13  libSystem.B.dylib                       0x94b72259 _pthread_start + 345
14  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 21:  Java: Low Memory Detector
7   libjvm.dylib                            0x2dfc89d4 JVM_IsPrimitiveClass + 13416
Thread 22:  Java: VM Periodic Task Thread
4   libjvm.dylib                            0x2dfcb479 JVM_IsPrimitiveClass + 24333
Thread 23:  Java: FelixDispatchQueue
11  ???                                     0x3c803e31 0 + 1015037489
12  ???                                     0x3c803e31 0 + 1015037489
13  ???                                     0x3c80430d 0 + 1015038733
14  ???                                     0x3c801374 0 + 1015026548
15  libjvm.dylib                            0x2dfa81ef JVM_Lseek + 205608
16  libjvm.dylib                            0x2dfa7f63 JVM_Lseek + 204956
17  libjvm.dylib                            0x2dfb4935 JVM_StartThread + 3022
18  libjvm.dylib                            0x2dfb47c5 JVM_StartThread + 2654
19  libjvm.dylib                            0x2dfb4743 JVM_StartThread + 2524
20  libjvm.dylib                            0x2dfb459d JVM_StartThread + 2102
21  libjvm.dylib                            0x2dfb43db JVM_StartThread + 1652
22  libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
23  libSystem.B.dylib                       0x94b72259 _pthread_start + 345
24  libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 24:  Java: FelixStartLevel
11  ???                                     0x3c80430d 0 + 1015038733
Thread 25:  Java: FelixPackageAdmin
Thread 26:  Java: Code Model Worker
3   libjvm.dylib                            0x2e1b256d JVM_RaiseSignal + 393445
4   libjvm.dylib                            0x2e1f2ea2 JVM_RaiseSignal + 657946
5   ???                                     0x3c80b9d9 0 + 1015069145
6   ???                                     0x3c803e31 0 + 1015037489
7   ???                                     0x3c803e31 0 + 1015037489
8   ???                                     0x3c80430d 0 + 1015038733
9   ???                                     0x3c804473 0 + 1015039091
Thread 27:  Java: Code Model Worker
Thread 28:
1   libSystem.B.dylib                       0x94b9e9c5 nanosleep$UNIX2003 + 188
2   com.adobe.flash.flbridge                0x29e8c93b ScObjects::Thread::sleep(unsigned int) + 59
3   com.adobe.flash.flbridge                0x29e88799 ScObjects::BridgeTalkThread::run() + 185
4   com.adobe.flash.flbridge                0x29e8cca8 ScObjects::Thread::go(void*) + 168
5   libSystem.B.dylib                       0x94b72259 _pthread_start + 345
6   libSystem.B.dylib                       0x94b720de thread_start + 34
Thread 29:
0   libSystem.B.dylib                       0x94b44b42 semaphore_wait_signal_trap + 10
1   libSystem.B.dylib                       0x94b726f8 _pthread_cond_wait + 1089
2   libSystem.B.dylib                       0x94bbb05f pthread_cond_wait + 48
3   ...ia.Flash Player.authplaylib          0x23e0e11f 0x239be000 + 4522271
4   ...ia.Flash Player.authplaylib          0x239d825f 0x239be000 + 107103
5   ...ia.Flash Player.authplaylib          0x23e0e20c 0x239be000 + 4522508
6   ...ia.Flash Player.authplaylib          0x23e0e250 0x239be000 + 4522576
7   ...ia.Flash Player.authplaylib          0x23e0e376 0x239be000 + 4522870
Thread 30:
Thread 31:
Thread 32:
Thread 33:  com.apple.CFSocket.private
0   libSystem.B.dylib                       0x94b63ac6 select$DARWIN_EXTSN + 10
1   com.apple.CoreFoundation                0x9a360c53 __CFSocketManager + 1091
Thread 34:  Java: Thread-4
3   libjvm.dylib                            0x2e042eb1 JVM_MonitorNotify + 916
4   libjvm.dylib                            0x2e0463d1 JVM_Sleep + 254
5   libjvmlinkage.dylib                     0x260caa68 JVM_Sleep + 72
6   ???                                     0x3c80b9d9 0 + 1015069145
9   ???                                     0x3c801374 0 + 1015026548
10  libjvm.dylib                            0x2dfa81ef JVM_Lseek + 205608
11  libjvm.dylib                            0x2dfa7f63 JVM_Lseek + 204956
12  libjvm.dylib                            0x2dfb4935 JVM_StartThread + 3022
13  libjvm.dylib                            0x2dfb47c5 JVM_StartThread + 2654
14  libjvm.dylib                            0x2dfb4743 JVM_StartThread + 2524
15  libjvm.dylib                            0x2dfb459d JVM_StartThread + 2102
16  libjvm.dylib                            0x2dfb43db JVM_StartThread + 1652
17  libjvm.dylib                            0x2df0e5e0 jio_snprintf + 39319
Thread 35:
0   libSystem.B.dylib                       0x94b44b5a semaphore_timedwait_signal_trap + 10
1   libSystem.B.dylib                       0x94b726e1 _pthread_cond_wait + 1066
2   libSystem.B.dylib                       0x94ba15a8 pthread_cond_timedwait_relative_np + 47
3   ...ia.Flash Player.authplaylib          0x23e0e0e7 0x239be000 + 4522215
4   ...ia.Flash Player.authplaylib          0x23b9e9de 0x239be000 + 1968606
Thread 36:
4   ...ia.Flash Player.authplaylib          0x23ab5913 0x239be000 + 1014035
Thread 37:
3   com.apple.audio.CoreAudio               0x93cfe3ab CAGuard::WaitFor(unsigned long long) + 219
4   com.apple.audio.CoreAudio               0x93d013dd CAGuard::WaitUntil(unsigned long long) + 289
5   com.apple.audio.CoreAudio               0x93cfecda HP_IOThread::WorkLoop() + 1892
6   com.apple.audio.CoreAudio               0x93cfe571 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
7   com.apple.audio.CoreAudio               0x93cfe488 CAPThread::Entry(CAPThread*) + 140
Thread 38:
3   ...ia.Flash Player.authplaylib          0x24180a2f ExternalPlayer_Initialize + 3454847
4   ...ia.Flash Player.authplaylib          0x24138ddb ExternalPlayer_Initialize + 3160875
Thread 39:
Thread 40:
Thread 41:
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0xbf81c0d8  ebx: 0x011f591b  ecx: 0xbfffcc24  edx: 0xbf81c0d4
  edi: 0x00000010  esi: 0x0000002f  ebp: 0xbf807828  esp: 0xbf7f2ef0
   ss: 0x0000001f  efl: 0x00010286  eip: 0x011f5916   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
  cr2: 0xbf7f2eec
Binary Images:
    0x1000 -  0x1b81fe7 +com.adobe.flash 12.0.0.481 (12.0.0) <CFAB9248-6011-0498-4D7A-985E1FB68592> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
0x272a000 -  0x28befff +com.adobe.PlugPlug 3.0.0.383 (3.0.0.383) <2205B6E1-7C9E-1892-EC68-C1B326C727A8> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x2966000 -  0x2a4efe3 +com.adobe.AXEDOMCore AdobeAXEDOMCore 3.7.101.18636 (3.7.101.18636) <2540764B-C2F2-61D7-EFBA-6663171FD19A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/Adob eAXEDOMCore
0x2adf000 -  0x2b7dfe3 +libicucnv.40.0.dylib 40.0.0 (compatibility 40.0.0) <D11DC46F-D58E-B17C-9356-46F593D5A7CF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libic ucnv.40.0.dylib
0x2b9f000 -  0x2cd4fe7 +libicui18n.40.0.dylib 40.0.0 (compatibility 40.0.0) <8BE3FE71-0CE6-2B93-B5F2-B4F0DD274B91> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUInternationalization.framework/Version s/4.0/libicui18n.40.0.dylib
0x2d48000 -  0x2e39fef +libicuuc.40.0.dylib 40.0.0 (compatibility 40.0.0) <4CF7066A-6E82-FF80-93E6-6849149FBB98> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuu c.40.0.dylib
0x2e76000 -  0x3bbbff7 +libicudata.40.0.dylib 40.0.0 (compatibility 40.0.0) <015E6351-4F42-00C1-2096-BEE385B275B1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata .40.0.dylib
0x3bce000 -  0x3bd9ff7 +libChar16.dylib ??? (???) <5E278E11-8234-CB11-AAC9-090FBD037DB7> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/libChar16.dylib
0x3be2000 -  0x3c04fff +libCoreTypes.dylib ??? (???) <5799BD8C-B334-518F-3F6F-EAA503B43831> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/libCoreTypes.dylib
0x3c1c000 -  0x3e4afff  com.apple.carbonframeworktemplate 1.0 (1.0) <9F3FE9F2-8834-4654-C0D0-F4F356E6A906> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
0x4101000 -  0x4105ff7  com.apple.JavaVM 13.9.2 (13.9.2) <CD170723-E4D4-8391-3ABA-DE66D4FF1A06> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x410d000 -  0x5777fff +com.adobe.AILib AILib version 16.0.0 (16.0.0.646) <317A871E-E0A5-8C5E-B60F-7448ADEBEDBD> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
0x67f0000 -  0x684bfff +com.adobe.aiport aiport version 16.0.0 (16.0.0.646) <59612576-B2F2-BF25-B09D-6120A3B1462C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aiport.framework/Versions/A/aiport
0x688b000 -  0x68ebfff +com.adobe.filterport filterport version 16.0.0 (16.0.0.646) <AF193FFA-F555-2379-81B3-7DA07698E466> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/filterport.framework/Versions/A/filterpor t
0x6936000 -  0x6936ffb +com.adobe.SPBasic SPBasic version 16.0.0 (16.0.0.646) <936C3F3E-8DDD-50EC-D247-C1F242633914> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
0x693b000 -  0x6957ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/Ado bePDFSettings
0x6971000 -  0x6aedff3 +com.adobe.ACE AdobeACE 2.19.18.19822 (2.19.18.19822) <2EC89B0E-6B51-4F7F-314A-FB6E18BFC36D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x6afc000 -  0x7097fef +com.adobe.AGM AdobeAGM 4.26.20.19822 (4.26.20.19822) <F394945E-943B-B99F-9B45-07E96C293C05> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x7107000 -  0x7141fef +com.adobe.ARE AdobeARE 1.5.02.19822 (1.5.02.19822) <2A3CBF43-F63E-B5B6-19EA-A2C392CA92F4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x7147000 -  0x7162fff +com.adobe.BIB AdobeBIB 1.2.02.19822 (1.2.02.19822) <CD35337B-CA58-50D9-5AAE-74E720CCE415> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x7168000 -  0x718efff +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <606DA5E0-CCB3-90B2-3971-A48349DA046A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
0x7194000 -  0x74bbffb +com.adobe.CoolType AdobeCoolType 5.10.31.19822 (5.10.31.19822) <A5344CC0-BD71-A071-A001-EDB3A28B9A8D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
0x74f3000 -  0x78eefe7 +com.adobe.MPS AdobeMPS 5.8.0.19673 (5.8.0.19673) <D65ABA15-80D2-3F1C-2500-EEF873019149> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x794b000 -  0x7a4ffef +com.adobe.PDFPort AdobePDFPort 2.1.0.19734 (2.1.0.19734) <71232DFD-06FB-837B-8246-BD20F862B5E3> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePD FPort
0x7a68000 -  0x8260ffb +com.adobe.PDFL PROD_MAJOR.PROD_MINOR.PROD_STEP (10.0.1.18562) <F24575DF-1B4D-B13E-1525-3C7F5CB88B3E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
0x82eb000 -  0x8313feb +com.adobe.AXE8SharedExpat AdobeAXE8SharedExpat 3.7.101.18636 (3.7.101.18636) <C38ACBCE-04AA-DF40-FF79-29377F25CDAF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
0x8332000 -  0x835aff3 +com.adobe.AXE16SharedExpat AdobeAXE16SharedExpat 3.7.101.18636 (3.7.101.18636) <AD333DEF-C5AC-1F75-0486-DF86F89433CD> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/ A/AdobeAXE16SharedExpat
0x8379000 -  0x83d5fef +com.adobe.AdobeXMPCore Adobe XMP Core 5.3 -c 11 (66.145661) <123A0829-A85B-6E67-0E48-4F37B08E4C03> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x83de000 -  0x8456fe3 +com.adobe.FileInfo.framework Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 (66.145433) <EF13921E-1CC6-2891-0EEC-D8D8C68D5D87> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x8465000 -  0x8644ffb +com.adobe.owl AdobeOwl version 4.0.93 (4.0.93) <D102FCD2-496D-5322-AEC0-7A5091CAA2CA> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x8671000 -  0x971dff3 +com.adobe.psl AdobePSL 13.0.0.19655 (13.0.0.19655) <47A9AAEC-43CD-17C9-6E58-6312315FC15D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x9896000 -  0x9ac0ffb +com.adobe.linguistic.LinguisticManager 6.0.0 (17018) <DE928A0E-AE8F-4FB7-6B6C-C52E4FD366A1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/Adob eLinguistic
0x9b32000 -  0x9b35ffb +com.adobe.AdobeCrashReporter 6.0 (6.0.20120201) <6CE1936E-6AC7-6900-769B-876CBB68B5BC> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
0x9b3d000 -  0x9f70ffb +com.adobe.dvaui.framework 5.0.0 (5.0.0.0) <EAD7D965-79BB-EA89-AB42-692578840BA8> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0xa3a9000 -  0xa55eff3 +com.adobe.dvacore.framework 5.0.0 (5.0.0.0) <EDDA1DA8-726A-0F1E-8733-CF6A482F307C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0xa6ac000 -  0xaabffe7 +com.adobe.dvaadameve.framework 5.0.0 (5.0.0.0) <E717BB78-EC59-A9C3-B02B-91A7D46DDBB3> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadamev e
0xb0d0000 -  0xb1b2ff3 +com.adobe.amtlib amtlib 6.0.0.93 (6.0.0.93) <2218F05B-09B7-AE0E-5EF7-98FBA5DF9C86> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0xb1c1000 -  0xb22effb +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1652) <82DA9279-45D2-AD40-C86C-F5A94B9DAAFF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSessio n
0xb27d000 -  0xb2b1ff7 +com.adobe.pip ??? (6.0.0.1654) <21A87289-747E-A0BD-2692-F9E844932E26> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
0xb2bd000 -  0xb3fdfeb +com.winsoft.wrservices WRServices 5.0.0 (5.0.0) <6D085279-1185-E7F0-B0D8-FBADBA062516> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
0xb46f000 -  0xb477ff7 +com.adobe.boost_date_time.framework 5.0.0 (5.0.0.0) <6397AF50-419F-3030-C6D6-A28D34CF3412> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boos t_date_time
0xb48f000 -  0xb4a7ff3 +com.adobe.boost_filesystem.framework 5.0.0 (5.0.0.0) <8DC64C9A-155F-DE79-3521-8869C4A2661D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boo st_filesystem
0xb4c8000 -  0xb572ffb +com.adobe.boost_regex.framework 5.0.0 (5.0.0.0) <F143073E-6033-B137-7633-9601D846FC1A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_re gex
0xb5f7000 -  0xb602ff7 +com.adobe.boost_signals.framework 5.0.0 (5.0.0.0) <5F9FB957-8AC2-A2FD-1518-9F9D978B0C58> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_ signals
0xb616000 -  0xb618ff3 +com.adobe.boost_system.framework 5.0.0 (5.0.0.0) <5641DBC5-37C4-7349-4BB4-FC19F46EEFFC> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_s ystem
0xb61e000 -  0xb62aff7 +com.adobe.boost_threads.framework 5.0.0 (5.0.0.0) <6F6A3465-894D-2E05-9FDE-16A15486E583> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_ threads
0xb646000 -  0xb7f9fe3 +com.adobe.AFlamingo AFlamingo 2.3.102.19287 (2.3.102.19287) <A04AE11D-8128-3324-295F-504CBAD447E1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
0xb815000 -  0xb81cffb +com.adobe.ape.shim 3.3.8.19346 (3.3.8.19346) <B711CAA7-29D6-D5CF-CE1B-A611896C8D87> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0xb824000 -  0xb8edfeb +FlashIK Framework ??? (1.0) <A8AFFB46-F2F7-FBFF-CF77-6BC999E1D266> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
0xb976000 -  0xb9aaff7 +com.adobe.pff.framework 1.0 (1.0) <E053457E-4AA0-D931-14AF-37BFE91AA1E4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
0xb9d3000 -  0xc376fef +com.adobe.AFlame AFlame 2.03.54.19287 (2.03.54.19287) <21495560-EA23-BCA2-8E91-9F0C1EF440EB> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
0xc3ea000 -  0xc419fff +com.adobe.contextui.framework 5.0.0 (5.0.0.0) <109B01C7-7CB9-D3CA-2CBB-B8D4ADC7AE3E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/contextui.framework/Versions/A/contextui
0xc460000 -  0xc484fe7 +com.adobe.dvaunittesting.framework 5.0.0 (5.0.0.0) <B32EF0E4-EBCF-6A17-56B2-FC5F2A969F45> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaun ittesting
0xc4bc000 -  0xc4dbfff +libtbb.dylib ??? (???) <6EA19434-60D6-505D-CB6F-5CA562A0F2A7> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/libtbb.dylib
0xc4f2000 -  0xc4fafef +libtbbmalloc.dylib ??? (???) <7A79ED70-A4AC-737A-2FAA-63B6FB29D4ED> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/libtbbmalloc.dylib
0xc509000 -  0xc5c4fef +com.adobe.AdobeXMPFiles Adobe XMP Files 5.4 -f 49 (66.145661) <B8855D3A-C827-D9EB-040E-F808043458DA> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeX MPFiles
0xc5f3000 -  0xc5f8ff7  JavaLaunching ??? (???) <A31CAC7D-F21D-F69F-556D-8A2697A625DB> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/ JavaLaunching
0xc600000 -  0xc600ff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <72FF6A91-C3EC-4634-A0FB-E1586C2404E4> /usr/lib/libmx.A.dylib
0xc603000 -  0xc643ff7  com.apple.vmutils 4.2 (106) <92BB4844-304C-C7AB-1F9B-686537C56099> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
0xc65c000 -  0xc65fffb +com.adobe.dvaflashview.framework 5.0.0 (5.0.0.0) <F06AF987-2A15-A8B9-11C9-2368422D061E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflas hview
0xc66e000 -  0xc740fff +com.adobe.dvaworkspace.framework 5.0.0 (5.0.0.0) <2B746397-82F4-3C89-28C1-1EC7EE317435> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvawork space
0xc85d000 -  0xc85eff7  com.apple.textencoding.unicode 2.3 (2.3) <A7D310DB-A5E6-C834-F72F-A66453834CC0> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x11ddc000 - 0x11dddff3 +com.macromedia.Flash.flastoragelib 9.0 (9.0) <AB678254-543D-CC50-3CF8-EC0AA01D99D4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStora geLib
0x11de2000 - 0x11de3ff7  ATSHI.dylib ??? (???) <8791C226-0725-314F-5897-BAAE57CA1EEE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x11df5000 - 0x11df9ff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x21f78000 - 0x21f8bff7 +com.adobe.AdobeSFL AdobeSFL 1.1.0.18561 (1.1.0.18561) <5A153C87-DD7A-CE28-2E93-7DC120D4244F> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
0x21f92000 - 0x21fa0fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <1825F5DF-491F-FDD5-3ABB-3FAC1EDC4357> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
0x21fa4000 - 0x21faaff7  com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x21fc5000 - 0x21fd7ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <3057675E-16A3-EC0C-A764-5CADB6C5ECD2> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
0x22fc8000 - 0x22fcaff7 +com.macromedia.Flash.FLfile 12.0.0.481 (12.0.0) <639D8AF3-69A7-4D91-5826-F54C86AB1BD1> /Applications/Adobe Flash CS6/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
0x239be000 - 0x243b0ff3 +com.macromedia.Flash Player.authplaylib 10.2.153.2 (10.2.153.2) <3CFE191B-E5E1-6C47-46DB-FE24C06872B7> /Applications/Adobe Flash CS6/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLi b
0x24652000 - 0x246a6fe7 +com.adobe.ape 3.3.8.19346 (3.3.8.19346) <0B80F7A7-EC10-A7C7-5E6E-787953553C55> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/adbeapecore
0x24800000 - 0x24872fef +com.adobe.adobe_caps adobe_caps 6.0.29.0 (6.0.29.0) <E4ADECD5-05B4-E78B-09D8-E45FD640E84D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0x2506c000 - 0x25073ff7  libverify.dylib 1.0 (1.0) <EB70DFA9-BBE9-3267-97B8-47FCBDD333CF> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libverify.dylib
0x2507f000 - 0x250c2ff3 +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 6.0.0.24 (6.0.0.24) <4B40551F-5306-C836-02AD-109826BD580C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A /UpdaterNotifications
0x25258000 - 0x2525dff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <31610F71-4447-CC8F-2859-4B881BB48F9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libFontStreams.A .dylib
0x252ec000 - 0x25313ffb +ServiceManager-Launcher.dylib 389.0.0 (compatibility 2.5.0) <4EEAF886-0B48-9FF4-BE65-41E222123A50> /Library/Application Support/Adobe/CS6ServiceManager/lib/ServiceManager-Launcher.dylib
0x25327000 - 0x25349ff7 +com.adobe.flash.cs6.airAndroid 12.0.0.0 (12.0.0) <48421B0A-923E-5940-9F04-B00DA3A75C11> /Applications/Adobe Flash CS6/Common/Configuration/External Libraries/Air_Android.bundle/Contents/MacOS/Air_Android
0x2535d000 - 0x2536cfff +com.yourcompany.PointGrid ??? (1.0) <2CB987CD-6752-D333-7F4F-A6713A901947> /Applications/Adobe Flash CS6/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
0x260c9000 - 0x260d0ffb  libjvmlinkage.dylib ??? (???) <40E32914-14BE-2928-DA0B-AE59EA90565A> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libjvmlinkage.dylib
0x26c84000 - 0x26c8cff7  JavaNativeFoundation ??? (???) <4A0385CE-2C49-63F7-5B86-E4A3A94E0EB0> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/Jav aNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x2735c000 - 0x27384ff7 +com.adobe.flash.cs6.air 12.0.0.0 (12.0.0) <871E06CB-E151-DD97-46AB-A8B2E9D75665> /Applications/Adobe Flash CS6/Common/Configuration/External Libraries/Air_Desktop_iOS.bundle/Contents/MacOS/Air_Desktop_iOS
0x27987000 - 0x27990fe7  com.apple.java.JavaRuntimeSupport 13.9.2 (13.9.2) <A595DF4F-A041-FB8C-1104-B6847B377C06> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/Jav aRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x280b6000 - 0x28113fef +com.yourcompany.Brush ??? (1.0) <2136D27E-974D-81F0-6078-492B233E16FC> /Applications/Adobe Flash CS6/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
0x2815c000 - 0x28168ff7  libzip.jnilib ??? (???) <0AFEDE34-013D-989B-D8BC-4E44ACF6B223> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libzip.jnilib
0x29e6b000 - 0x29eb2fff +com.adobe.flash.flbridge 12.0.0.481 (12.0.0) <9301CA9F-DABA-0BB4-84D3-B9DAE690711D> /Applications/Adobe Flash CS6/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
0x2a560000 - 0x2a5e3ffb +com.yourcompany.Collision ??? (1.0) <F0E00160-1946-C591-89EC-FBD99ACCC449> /Applications/Adobe Flash CS6/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
0x2a9a1000 - 0x2a9bdff7  libjava.jnilib ??? (???) <F70F7671-1494-8562-9D83-0360ED4152E3> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libjava.jnilib
0x2d400000 - 0x2d501fff +com.yourcompany.Stroke ??? (1.0) <B1BDF135-128A-A5D9-3EC0-E0EBEC447500> /Applications/Adobe Flash CS6/Common/Configuration/External Libraries/Stroke.bundle/Contents/MacOS/Stroke
0x2df00000 - 0x2e264fe7  libjvm.dylib ??? (???) <B839ADE9-AF2B-5D64-AB4E-7E6AC18907D0> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bund le/Libraries/libjvm.dylib
0x40000000 - 0x400c4fe3 +com.adobe.JP2K 2.0.0 (2.0.0.18562) <FFA540EA-6CEB-F4D1-E0EF-A844A536D499> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x70000000 - 0x700cbfff  com.apple.audio.units.Components 1.6.5 (1.6.5) <412DBD1B-E9B5-E67C-99E4-820BF38239AC> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAud io
0x8fe00000 - 0x8fe4163b  dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
0x90003000 - 0x90015ff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x90094000 - 0x90094ff7  liblangid.dylib ??? (???) <FCC37057-CDD7-2AF1-21AF-52A06C4048FF> /usr/lib/liblangid.dylib
0x90095000 - 0x90258feb  com.apple.ImageIO.framework 3.0.6 (3.0.6) <5BF202E9-730A-3675-4374-E5300BC8ED10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x90259000 - 0x9026aff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9026b000 - 0x902b1ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x902b2000 - 0x903dafe7  com.apple.WebKit 6534.57 (6534.57.2) <4CB86278-4657-3503-8042-074628222DF3> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x903db000 - 0x90420ff7  com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
0x90421000 - 0x904ecfef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x904ed000 - 0x91265fe7  com.apple.WebCore 6534.57 (6534.57.2) <6AF29D9A-F549-5BE7-3842-CFF75FC46360> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/Web Core.framework/Versions/A/WebCore
0x91266000 - 0x912adffb  com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versi ons/A/CoreMediaIOServices
0x912ae000 - 0x912b4fe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x915a5000 - 0x91816fef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x91817000 - 0x91878fe7  com.apple.CoreText 151.13 (???) <23F359DA-D845-5C50-4DF3-19E858CF2B2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x918a4000 - 0x918e8fe7  com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x918e9000 - 0x91981fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x91982000 - 0x91a2efe7  com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x91a2f000 - 0x91b0ffe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x91b3a000 - 0x91b7dff7  libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x91bb8000 - 0x91bf2ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <A6C207E3-7B42-926D-9C93-BE3F50B92496> /usr/lib/libcups.2.dylib
0x91bf3000 - 0x91bf7ff7  libGIF.dylib ??? (???) <9E51F8ED-83B4-DA41-1E2F-CFA726936A30> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c75000 - 0x91c7fffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x91c80000 - 0x91c8eff7  com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x91c8f000 - 0x91c9fff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <95DC4010-ECC4-3A75-5DEE-11BB2AE895EE> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
0x92077000 - 0x92130fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x92131000 - 0x92173ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x92174000 - 0x9217eff7  com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
0x9219e000 - 0x921eeff7  com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x921ef000 - 0x92210fe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x92211000 - 0x9233effb  com.apple.MediaToolbox 0.484.60 (484.60) <A7FE2739-64A7-40EB-A6E7-69FBCE3C87D4> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
0x92344000 - 0x923a8fff  com.apple.htmlrendering 72 (1.1.4) <0D22B190-513B-7FF6-39FC-9D336285DE08> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x923a9000 - 0x923adff7  libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x923ae000 - 0x92488fff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x92495000 - 0x924a2ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x924a3000 - 0x924a4ff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <1DD14B2E-E466-1A45-5CF7-947766F0ECD9> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
0x924a5000 - 0x92542fe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x92556000 - 0x92603fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x92604000 - 0x92686ffb  SecurityFoundation ??? (???) <C4506287-1AE2-5380-675D-95B0291AA425> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x92687000 - 0x927b5fe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x927eb000 - 0x927eefe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x927ef000 - 0x92868ff7  com.apple.PDFKit 2.5.1 (2.5.1) <A068BF37-03E0-A231-2791-561C60C3ED2B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
0x92873000 - 0x92899ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9289a000 - 0x928ddff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x928de000 - 0x928e5ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <A5FF7623-9F55-0364-AD9B-42CF13C677C1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x928e6000 - 0x92ac8fff  com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
0x92b39000 - 0x92c7cfef  com.apple.QTKit 7.7 (1791) <74F00760-A831-B8F2-869D-84C1F2366204> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x93bd1000 - 0x93c89feb  libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x93c8a000 - 0x93cddff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x93cde000 - 0x93d58fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93d59000 - 0x93d75fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x93d7b000 - 0x93d9fff7  libJPEG.dylib ??? (???) <C43FD809-08B6-629D-8980-D7B0ECEA20A9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x93da0000 - 0x93e1bfff  com.apple.AppleVAFramework 4.10.27 (4.10.27) <BFD2D1CA-535C-F16F-0EB5-04905ABD65CF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
0x93e1c000 - 0x93e9fffb  com.apple.CoreSymbolication 2.1 (71) <34222139-6701-3F6B-A632-C5FBA8A53FA3> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
0x93ea0000 - 0x940cbff3  com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
0x940cc000 - 0x940e1fff  com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x940e2000 - 0x94100fe7  libPng.dylib ??? (???) <5B979A83-8CE7-6BD7-B84C-A2D1119B378D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94101000 - 0x94128ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <F45520B0-6B27-CD57-54B1-203FE32120DA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
0x94142000 - 0x941b0ff7  com.apple.QuickLookUIFramework 2.3 (327.7) <7F89C0A1-310F-ACF1-AA6E-4ADFA4DC98DC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
0x94210000 - 0x94210ff7  com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x94211000 - 0x94627ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <9D89FCB3-24C9-8FCF-DB49-27B184AC3222> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x94628000 - 0x9467eff7  com.apple.MeshKitRuntime 1.1 (49.2) <CB9F38B1-E107-EA62-EDFF-02EE79F6D1A5> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x9467f000 - 0x946b2ff7  com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x946b3000 - 0x946bcff7  com.apple.DiskArbitration 2.3 (2.3) <6AA6DDF6-AFC3-BBDB-751A-64AE3580A49E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x94712000 - 0x9474dffb  libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x948af000 - 0x9491eff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x94aff000 - 0x94b43ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x94b44000 - 0x94cebff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x94cec000 - 0x94cefff7  libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x94cf0000 - 0x94cf2ff7  libRadiance.dylib ??? (???) <5F803B4A-B294-BA94-FB68-E8756EE41B20> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94d09000 - 0x94d21ff7  com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94d22000 - 0x94e5ffe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x94e99000 - 0x94e9cff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x94eee000 - 0x94ef3ff7  com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x94ef4000 - 0x94ef4ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x94ef5000 - 0x953b0ff7  com.apple.VideoToolbox 0.484.60 (484.60) <B53299EC-E30F-EC04-779D-29B7113CC14A> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
0x9549c000 - 0x954c4ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <E761F29A-328B-29D9-3DF0-023F2C21E500> /usr/lib/libxslt.1.dylib
0x954fa000 - 0x95501ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x955e1000 - 0x95601fe7  libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
0x95737000 - 0x957e5ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x95e98000 - 0x96192fef  com.apple.QuickTime 7.6.6 (1791) <8E56F3DC-725B-0299-7E62-8599CA6EC4C0> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x96193000 - 0x96193ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x96194000 - 0x961fefe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x96273000 - 0x962b4ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x962b5000 - 0x962e6ff7  libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x962e7000 - 0x964c0fff  libType1Scaler.dylib ??? (???) <04AF2B34-81D4-97E9-BD56-387D37C16F46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x964c1000 - 0x9657dfff  com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x9657e000 - 0x9682cfe7  com.apple.JavaScriptCore 6534.57 (6534.57.3) <5B18B308-DBB2-7133-DE56-494C2FA1848B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
0x9682d000 - 0x96830ffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x96831000 - 0x96831ff7  com.apple.quartzframework 1.5 (1.5) <7DD4EBF1-60C4-9329-08EF-6E59731D9430> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x9683f000 - 0x96845fff  com.apple.CommonPanels 1.2.4 (91) <CE92759E-865E-8A3B-1488-ECD497E4074D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x96846000 - 0x96846ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x96847000 - 0x96c98fef  com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
0x96d9d000 - 0x97003ff7  com.apple.security 6.1.2 (55002) <3FA54D69-5476-78DD-0AFC-D6697263890E> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x97004000 - 0x97018fe7  libbsm.0.dylib ??? (???) <B328FA0A-899C-4FC4-F2AC-2FDC08819CD2> /usr/lib/libbsm.0.dylib
0x97019000 - 0x97027fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x97230000 - 0x97234ff7  IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x97235000 - 0x97249ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <9F5CE4F7-D05C-8C14-4B76-E43D07A8A680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9724a000 - 0x9733eff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x9733f000 - 0x97349fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <DE0E0EF6-8190-3F65-6BDD-5AC9D8A025D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x9734a000 - 0x973f2ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x973f3000 - 0x974f3fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <BE7FCD73-03B5-25A4-FCA4-D4980F1488D6> /usr/lib/libxml2.2.dylib
0x974f4000 - 0x97531ff7  com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/Core Media
0x97532000 - 0x9753aff7  com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
0x9753b000 - 0x975bbfeb  com.apple.SearchKit 1.3.0 (1.3.0) <7AE32A31-2B8E-E271-C03A-7A0F7BAFC85C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x975e3000 - 0x97a18ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <4D2F47EF-BD32-1E3C-6A0A-438896ADE2BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x97a19000 - 0x97a24ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x97a25000 - 0x97ab7fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x97abe000 - 0x97bc0fef  com.apple.MeshKitIO 1.1 (49.2) <D0401AC5-1F92-2BBB-EBAB-58EDD3BA61B9> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitIO.framework/Versions/A/MeshKitIO
0x97bc1000 - 0x97c1eff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x97d82000 - 0x97dbfff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x98420000 - 0x9847afe7  com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
0x9851c000 - 0x98546ff7  com.apple.shortcut 1.1 (1.1) <08A1868D-FEF4-8FB3-D814-79385DCBEC7D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
0x98547000 - 0x9857efef  com.apple.DebugSymbols 2.1 (87) <CAB6A365-054E-3C53-8725-8495F6D3BEE6> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
0x9870a000 - 0x9870aff7  com.apple.Cocoa 6.6 (???) <5A785062-1ABB-2A54-BAAC-8FEF95275E05> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9870b000 - 0x98817fe7  libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
0x98818000 - 0x98823ff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x98824000 - 0x98b44ff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x98b45000 - 0x98e69fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x98e6a000 - 0x98e89ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x98e8a000 - 0x98ebdfff  libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x98ebe000 - 0x98ecaff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x98f14000 - 0x99096fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <50A70082-F800-93D8-1A7C-C95AAB1F352C> /usr/lib/libicucore.A.dylib
0x990d1000 - 0x999b4ff7  com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x999b5000 - 0x999b7ff7  com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x999b8000 - 0x99a08fe7  libTIFF.dylib ??? (???) <E8B31850-BFD4-48E6-B264-A4340CD19929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x99a09000 - 0x99a39ff7  com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKi t
0x99a3a000 - 0x9a229557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9a22a000 - 0x9a22bff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x9a247000 - 0x9a247ff7  com.apple.ApplicationServices 38 (38) <EAF1BC8C-4FD4-4300-B8F7-4B24E49125E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x9a248000 - 0x9a2e3fe7  com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x9a2e4000 - 0x9a45ffe7  com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x9a460000 - 0x9a49eff7  com.apple.QuickLookFramework 2.3 (327.7) <6387A103-C7EF-D56B-10EF-5ED5FC7F33A5> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x9a50e000 - 0x9a51eff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <E276514D-394B-2FDD-6264-07A444AA6A4E> /usr/lib/libsasl2.2.dylib
0x9a51f000 - 0x9a555fff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x9a55e000 - 0x9a8c9ff7  com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9a8ca000 - 0x9a8cbff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9a8cc000 - 0x9a8eefef  com.apple.DirectoryService.Framework 3.6 (621.15) <F38894EA-2C13-7FC5-C084-94DA0B5B6B68> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
0x9a8ef000 - 0x9a947fe7  com.apple.datadetectorscore 2.0 (80.7) <3830B574-3B0B-76DA-390D-702D908A71F4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
0x9a948000 - 0x9a948ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9a949000 - 0x9aa4bfe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x9abad000 - 0x9abfafeb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
0xb0000000 - 0xb001afe3 +com.adobe.ahclientframework 1.7.0.56 (1.7.0.56) <928D8FAD-DEE7-F1D0-FE17-FA7F4E4C1E48> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <49C72FD1-891C-23C4-40E7-63DE3368C306> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <B7E8B785-D05F-F89B-5E18-EF854555926C> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: iMac11,2, BootROM IM112.0057.B00, 2 processors, Intel Core i3, 3.06 GHz, 4 GB, SMC 1.64f5
Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.14.6
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: WDC WD5000AAKS-40V6A0, 465.76 GB
Serial ATA Device: HL-DT-STDVDRW  GA32N
USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
USB Device: iPad, 0x05ac  (Apple Inc.), 0x12ab, 0xfa140000 / 6
USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0xfa120000 / 4
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 3
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0xfa111000 / 5
USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd110000 / 4
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd120000 / 3
[/code]
  • kglad
    Jul 21, 2002
    Feb 28, 2013 8:22 AM   in reply to yalp.com.br
    re-install flash cs6 pro.
    for your first try, you do not need to uninstall.
  • kglad
    Jul 21, 2002
    Feb 28, 2013 11:25 AM   in reply to yalp.com.br
    can you rollback your os to a time before the crashes started occuring?
  • kglad
    Jul 21, 2002
    Mar 1, 2013 6:34 AM   in reply to yalp.com.br
    contact adobe support:  www.adobe.com/support/chat/ivrchat.html
    Mar 6, 2013 10:08 AM   in reply to kglad
    I have the same issue since this morning. It seems like the latest Java update from Apple changed something that is making Flash not being able to display windows. Reinstalling did not make a difference.
    Flash is unusable so we need a solution.
    OSX 10.8.2
    Flash CS6
    Edit: Uninstalling AND removing preferences helps.
    Jul 18, 2013 10:08 AM   in reply to yalp.com.br
    Happens to me as well.  Very often.  Seems to be related in part to copy paste operations but I have has data losing crashes at all times using CS6 includeing when doing a "Test Movie" operation.  I have switched back to CS5.5 for almost all Flash work.  I wonder if reduced/refunded creative cloud fees are in order until these issies can be fixed?
    Jul 18, 2013 12:09 PM   in reply to yalp.com.br
    Sounds like Apple changed something. Over the years I've only worked with Windows so I can't comment to that. But I've had a couple of issues that would cause crashes or data loss:
    1. Restricted fonts installed in Win7 would make Flash Pro CS6 crash on startup. Adobe released an update and now this doesn't occur for me anymore. Workaround was to uninstall restricted fonts, start FP, and then install needed fonts.
    2. Flash Pro becomes extremely unstable anytime I try to debug with it so I've given up trying that. I debug only through trace statements now. I now develop all scripting in .as text files using an external editor. I use FP strictly for asset management and publishing.
    3. I've recently posted a bug with example code to the bugbase regarding sound files being lost from a .fla file under certain conditions. I have a commonAssets.fla with a folder I copy into my other projects containing the latest development assets. If the working app already has a 'common' asset folder I first rename it to 'commonold', before copying in the new folder. Then for instances that are tied directly to the old folder I swap out their asset to the matching one in the new folder. Normally Flash Pro doesn't allow 2 assets to have the same linkage, but you can copy in sound files from another fla with a matching linkage. This can be a problem in my case as the next step is to delete the 'commonold' asset folder. This fakes out the fla into thinking all versions of the sounds with the same linkage are also deleted. So when you save the fla, those sound assets do not get written out. But you won't find that out until you next load up that fla.
    The tip-off as to when the bug will happen turns out to be the popup dialog asking if you wish to replace the assets or stick them in another folder. If I don't get the popup and the new asset folder copies in cleanly then I know I'm good. Otherwise, I select 'replace', swap my old asset to the new folder, delete the old folder and then repeat the whole process a second time - the second copy-in always works.
    4. If working with internationalization of a fla make sure you only have the one file open in Flash Pro - I've had problems in the past with string tables not refreshing to show the current app I'm working on.
    Good luck getting up and running again.
