JBonavita
Coping MovieClip from one fla to another isn't working right
Feb 28, 2013 8:02 AM
I copied a movieclip from one fla to another one. The copy itself seems to have worked but when I call mysprite.addChild(mymovieclip) I get Parameter child must be non-null.
Is there more that has to be done to get the movie clip created?
    Feb 28, 2013 8:20 AM   in reply to JBonavita
    How does the code you show relate to the movieclip you copied over?  Where is the movieclip you copied over?
  • kglad
    Jul 21, 2002
    Feb 28, 2013 8:21 AM   in reply to JBonavita
    where is mymovieclip defined?
    Feb 28, 2013 8:32 AM   in reply to JBonavita
    In the code you gave mymovieclip is a variable name, not a type. If mymovieclip is the linkage name try this instead:
    var mc:mymovieclip = new mymovieclip();
    Alternatively if you are trying to make a class for your symbol your class just needs to extend MovieClip and then you set that as the base class in the advanced properties window.
