Replace footage will crash Premiere Pro CS6
Feb 28, 2013 9:26 AM
I have a serious problem with Premiere Pro CS6 when I want to replace footage in the project. I need to replace .R3D files to ProRes files that I encoded via MediaEncoder.
When I replace the clip (.R3D to ProRes) in project browser, Premiere crashes every time announcing:
"Sorry, a serious error has occurred that requires Adobe Premiere Pro to shut down..."
When reopening the project (the recovery project Premiere Pro tried to save while crashing), the name of the file is still the same, but the content of the file has changed to the ProRes clip (they are different in resolution). When I replace the clip again, the name of the clip also changes and does not crash - however the clip was already changed even the name wasn't.
If I then replace another clip (.R3D to ProRes), Premiere will crash again. This happens every time I try to replace a new clip (.R3D to ProRes).
If I replace the other way around (ProRes to .R3D), Premiere will not crash.
Please help. This is very annoying problem, and I need this resolved as soon as possible!
Thanks!
(MacPro, OSX 10.7.5, PremierePro CS6)
    Mar 2, 2013 7:24 AM   in reply to lastala
    For myself, I just don't have any RED or ProRes clips to test with.
    Mar 3, 2013 8:05 AM   in reply to lastala
    https://www.depositfiles.com/en/
    You can send files up to 10GB.
    Mar 3, 2013 1:59 PM   in reply to lastala
    Tried it with two files, an AVI file at the same resolution and an MXF file at 1920 x 1080.  Both worked fine, however, both also generated a low-level exception error with the Red importer.  This did not crash PP or interfere with work, though.
    Mar 4, 2013 7:48 AM   in reply to lastala
    Windows 8 Pro.
