CS5 - Recolor artwork not working?
Feb 28, 2013 10:35 AM
Tags: #recolor_artwork
I have a file with a number of artboards on which there are objetcs filled with 100% Magenta and some with 100% Magenta and 0,34% Yellow. I want to get rid of that 0,34% but Illy is refusing to cooperate.
Even selecting just two or three objects and trying to recolor using the Edit/Edit colors/Recolor Artwork dialog has no effect. I can change the color manually though, for one or more selected objects.
Any thoughts?
    Feb 28, 2013 11:23 AM   in reply to gaphic2
    Recolor artowrk will make as small a change as up to 2 decimal places.
    Check your document color mode, you may for exampel be in RGB and doing chanegs in CMYK, and that would give you such a result.
    If you need further help, please attach a screenshot showing the values and settings you are using, before and after.
    Make suere recolro art is checked.
