when I start up adobe photoshop 11, the screen freezes on "initializing model ...". the only way I know to fix the freeze problem is to reboot my computer.
Later on, I may need to do this workaround again. this workaround is very aggrevating. what do I need to do to fix this? I was under the impression I purchased a professional product that wouldn't freeze randomly.
For once, Please try launching Organizer/Editor (or both) from their respective .exe's by right clicking the .exe file and select 'Run as admin'. The .exe's are located at:
Organizer: C:\Program Files (x86)\Adobe\Elements 11 Organizer\PhotoshopElementsOrganizer.exe
Editor: C:\Program Files (x86)\Adobe\Photoshop Elements 11\PhotoshopElementsEditor.exe
~Andromeda
I did as andromeda14 asked above with the adobe photoshop organizer. It has been stuck on "initializing model..." for about 3 minutes now. just so you know, I did not reboot this morning and my laptop has been on for about the last 12 hours without a reboot.
When the program works correctly after a reboot, the program completes "initiating model..." in one or two seconds.
I do not see how picture data or metadata that I enter into photoshop organizer can be causing this problem. If my data were the problem, then why does a reboot correct the problem? I think it is more likely the progam has not cleaned up after itself (hung task or data in registry) after being shut down thus causing the program not to initiate properly after being started a second, third or fourth time.
Just so you know, the elements organizer app occasionally does start on the 2nd or subsequent time after a reboot. I have not been able to figure out why this occurs. I do know for sure that I will get 1 good start up after a reboot. after that, subsequent start ups may or may not work. I seems the longer I wait to start the second time, the more likely it will hang on "initiating model...".
Just so I know, are you an adobe tech support person or are you an expert user?
Close Elements.
Click the Start Button and then your user name (in place of mine) and navigate to:
C: Users >> 99Jon >> AppData >> Roaming >> Adobe >> Elements Organizer >>11.0 >> Organizer
Delete the PSA file (with key symbol) and delete Status.dat
After deleting these two files re-start the program
AppData may be a hidden system file. See the link to reveal hidden files.
http://windows.microsoft.com/en-US/windows7/Show-hidden-files
I had a freeze event at 7pm last night at "initializing model...". I rebooted to get going. this morning, the first time I tried starting the organizer program, it froze at "initializing model". I'm sure if I go in and delete the 2 files you suggest, it would most likely work for a while. Why can't you provide an option in the Organizer product to auto-delete those files so Organizer opens with some reliability? I don't have to do anything special to start other purchased software products like: Microsoft office products, Internet Explorer, Quicken, Turbotax, etc. Why is your product the only one that I would have to delete 2 files before I can use it reliably? I want you to understand, this is not a professional perminant fix.
These files are you settings files, they store things like your Preferences, which catalog you are using, etc. Deleting these forces the application back to it's defaults, the same as it was when you first opened it. Deleting this at every launch would undo some of the work you did the last time you used the application. If deleting these files allows the application to work for a short time, this means these files are being corrupted and thus the root cause of this issue has not yet been discovered. In cases like this, the most common culprit is another application running in the background preventing the file from saving correctly (such as anti-virus scanning the file during it's creation). To verify this, I would suggest shutting down all background processes, deleting the files mentioned, and then running the Organizer a couple times (open and close it). See if the behavior comes back.
I'm getting this adobe abend information. does this mean anything to you?
Files that help describe the problem:
C:\Users\Mark\AppData\Local\Temp\WERF3E4.tmp.WERInternalMetadata.xml
C:\Users\Mark\AppData\Local\Temp\WER124D.tmp.appcompat.txt
C:\Users\Mark\AppData\Local\Temp\WER1C4C.tmp.mdmp
would it help if i provide the content of these files?
Please refer to blog: http://psekb.blogspot.in/2013/03/pse-organizer-is-not-launching.html
Hope it resolves the issue.
~Andromeda
North America
Asia Pacific
