Hi all,
I shot and edited AVCHD 1080i30 (60i) square pixel video from a Sony NXCAM HXR-NX5U camcorder in Premiere CS6. I then exported the 1920x1080 edited mpeg2 blu-ray m2v file for import into Encore Cs6. Burning a blu-ray disc in Encore CS6 from this mpeg2 bluray m2v file is no problem and look great even with the default settings.
However, I also want to burn a standard DVD using the same HD Encore CS6 project without having to go back to Premiere CS6 and output a 710x480 mpeg-dvd file. I thought i could simply select the dvd format under the build tab in Encore thinking Encore would handle all the necessary conversions to burn a 720x480 DVD but the menus look jaggy and the video does not play smoothly.
Is it possible to burn a standard DVD correctly from an Encore CS6 HD project and content, or is it better to have Premiere CS6 output a 720x480 mpeg-dvd file and create a new standard 720x480 dvd Encore project instead?
Acording to Encore Help, it says "You can build the same project to DVD and Blu‑ray formats no matter which format you select in the New Project or Project Settings dialog box. Encore makes the appropriate adjustments to transcode the elements to the correct format.", but i'm not convinced Encore is doing things correctly.
Thanks.
Jim,
I tried a variation on your suggestion.
I exported a new m2v file using the mpeg-dvd from Premiere CS6 as you suggested with "Use Maximum Render Quality" checked to get better scaling from HD to SD. I imported it into my Blu-ray EncoreCS6 project by using the "Replace Asset" option and changed the "Project Settings" authoring Mode to "DVD" leaving the HD menu's "Aspect Ratio" at 16:9. I then built the disc using the "Build" tab DVD format and output settings.
It worked!
The jaggies are gone (except for some motion jaggies) and the DVD plays well.
I suppose I could have done something similar within Encore but I'll test that some other time.
North America
Asia Pacific
