Hello, this is a serious problem, very unhappy client
please help!
Here is a video I made detailing the problem. Please let me know if you need more information!
http://webvideoninja.com/uga/?seed=encore-cs6-issue
using a 2011 macbook pro, CS6 encore. did not use premiere for anything
took MPEG files direcly into CS6, spent hours creating a menu and linking
everything up, and ended up with a super blurry video that bounces up and down
before and after export to DVD.
the original video files are MPG files 750 X 576 size MPEG-2 Video AC3 Audio Channels 2.
They look great when played in quicktime, and get jumpy/bouncy/shakey immediately when imported to
encore. The quality improves a little bit after transcode (video is less blurry) but the
shaking and bouncy problem persists.
Thank you to anyone who can shed some light on this.
That is an odd size... please use one of these programs to verify
Report back with the codec details of your file, use the programs below... a screen
shot works well to SHOW people what you are doing
http://forums.adobe.com/thread/592070?tstart=30
For Mac http://mediainspector.massanti.com/
here is a sample clip (you can download it using the download button in the upper right of the screen)
https://www.dropbox.com/s/3iz0av9zq46jhf4/PuttingRoutine.mpg
here is the results from media inspector (thanks for introducing me to this, been needing this a long time)
General
Complete name :1/PuttingRoutine.mpg
Format : MPEG-PS
File size : 220 MiB
Duration : 4mn 42s
Overall bit rate : 6 516 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Duration : 4mn 42s
Bit rate mode : Variable
Bit rate : 6 131 Kbps
Nominal bit rate : 8 300 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.591
Stream size : 207 MiB (94%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Muxing mode : DVD-Video
Duration : 4mn 42s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 8.63 MiB (4%)
Ok... actually PAL standard of 720x576 not the 750x576 you initially stated
I don't do PAL (or Mac) but I see 2 potential problems
1st is that you have one file, not separate audio and video, which means that Encore must "de-mux" one file into two to build a DVD... which adds an extra step that may cause problems
2nd is that your file is top field first, while a DVD is "often/usually" lower field first... so check your settings to see if you can (or are?) force Encore to use the file as is, without re-transcoding to lower field first
Other than those 2 things, I don't see any glaring problems
These days, most PAL DVD players can play NTSC DVDs. Unless your clients have older players, you may be able to make a single NTSC DVD and keep everyone happy.
Of course, that would mean starting with NTSC footage, too.
If you are stuck going PAL>NTSC, then check out DVFilm Atlantis for Windows Pal to Ntsc and Ntsc to Pal Conversion of HD and SD files
Better results will come from Dan Isaacs' dv2film AviSynth script, but it has a steep learning curve.
Jeff
North America
Asia Pacific
