First frame of new clip, last frame of previous clip bug
Mar 1, 2013 6:03 PM
Tags: #pro #premiere #crash #bug #effect #clips #clip
I'm coming across what seems to be a bug in Premiere Pro CS6. When I apply an effect or edit an After effects project in Premiere Pro, the clip next to it seems to get a frame of the video without the effect then it changes to the next clip.
So it goes Clip with effect on > Next clip with 1 frame of previous clip but without effect > Next Clip with whatever footage.
Hopefully this makes sense? It's a really annoying bug.. any ideas?
    Mar 2, 2013 1:52 AM   in reply to Alex Canton
    I am not sure what you are doing to cause that problem.
    Try this:
    Put a short clip on a new sequence. Apply the Fast Blur and max it out. Go to the end of the clip. The last frame should also be blurred out.
    Put a different clip on the sequence after the first. You should see the blurred clip, then the new clip. Zoom way in to see the cut between the two clearly.
    Mar 2, 2013 7:29 AM   in reply to Alex Canton
    I've never seen this behavior myself.  Let's start here:
    FAQ: What information should I provide when asking a question on this forum?
    Feb 5, 2014 2:46 PM   in reply to Steven L. Gotz
    I see what you are trying to do, but i have the exact same problem as alex
    Im positive when mine does it, either the effect doesnt apply on the last frame, or it takes that last frame and puts it at the start of the next clip. I am sure they are frames of the same clip and there is no timeline error, i have zoomed in and looked and checked alot.
    This means i get an annoying flash of a frame from the previous clip over the start of the present one, i have restarted it and works fine, but after a while of editting, it just comes back again?
    Help much needed and appreciated?
    Oliver
    Feb 6, 2014 2:10 PM   in reply to Punkoli
    Start with those questions from post 2.
