clari_hope
Burning Flash movie to DVD
Mar 2, 2013 8:08 AM
Hi
I am creating a flash animation to be projected. I have to burn in onto a dvd. I have tried converting the .mov file that flash exports, and flv to mpeg. The preview looks fine, but every time the dvd quality is terrible. I have tried HD, h. 264, NTSC. I have also tried converting a .swf to mpeg with no luck.
I am using flash CS5.
Please help.
I was wondering if I try to burn the html file that flash creates to DVD, would that work? Or should I try exporting the image sequence and put it back together in another program such as Final Cut or imovie? Should I use something other than Encore to convert the files?
    Mar 2, 2013 8:06 AM   in reply to clari_hope
    What resolution is the original animation?  What frame rate?
    Mar 2, 2013 8:21 AM   in reply to clari_hope
    Terrible played back on a DVD player to a TV or ...?
    You can't have 15fps on a DVD.
    Mar 2, 2013 8:33 AM   in reply to clari_hope
    Does this have to be a DVD "Movie" or can you write a data disk that may be run from a computer to the projector?
    Mar 2, 2013 8:45 AM   in reply to clari_hope
    In that case, you are limited to what a DVD movie will allow... and your source material is not a good fit
    Mar 2, 2013 10:42 AM   in reply to clari_hope
    Link to DVD Demystified FAQ http://forums.adobe.com/thread/544206 may help
    Mar 3, 2013 8:45 AM   in reply to clari_hope
    1296x1728 15fps
    That's just never going to look as good on DVD.
    Recreate the animation using DVD standards: 720 x 480 using the Widescreen Pixel Aspect Ratio (1.2) at 23.976 fps.
    Mar 3, 2013 9:02 AM   in reply to clari_hope
    It's strange that a dvd would be so problematic, especially since it is not a long movie, it has no complicated video or images.
    See Jim's suggestion.
    DVD is TV, not computer; the specs that determine how DVDs behave on DVD players are very exacting. But primarily, you are no longer creating flash for computer, but for TV/DVD. Follow those rules and you'll get what you are after.
