freemanbryn
Undefined is not an object
Mar 2, 2013 9:08 AM
Tags: #error #not #pdf #bridge #output #object #undefined
Hello!
It seems this question may have been asked, but I cannot find an answer.
When creating a PDF from Bridge, I get the error message "undefined is not an object." I have figured out which images are causing this problem, but is there a way to "fix" them so that I can make a PDF?
They are named the same way that all of my other images are named, and re-saving them doesn't seem to help either.
Just to give some background, these are all images that have been submitted to me by multiple people. I have renamed all of the files to follow a naming convention (ex: ABC0001.tif, ABC0002.tif). The images that seem to be causing the problem are all from the same person.
Thanks for any help!
  • Omke Oudeman
    Nov 27, 2004
    Mar 2, 2013 3:45 PM   in reply to freemanbryn
    This might sound obvious because you also named open and resave files as no solution but you did rename using the existing file extension I presume? Otherwise also check if you have the correct permissions (read and write) for the files.
    And can you provide details about OS system, version and Bridge version?
