ItsGregHere
approach to draw a mountain outline & fill, but be able to adjust later?
Mar 2, 2013 3:43 PM
Tags: #path #paths #pen #vector_effects
What would be the best approach to draw a mountain outline using a vector approach & fill, but be able to adjust the outline later via a vector approach? (i.e. outline shouldn't get rasterized)
So the approach would need to be able to:
* create the outline & selection with a vector based approach
* vector selection has to be effectively saved for later
* modification later should support getting access to the original handles of the vector selection (say with Pen tool) and make adjustment
* after adjustement of the vector area is made, the fill should automatically occur on the extended or contracted area
Any advice on approach/which tools to use in CS6 to be able to do this?
    Mar 2, 2013 9:21 PM   in reply to ItsGregHere
    Just use the pen tool (p) and set the type to shape. The achor points can be selected with the direct select tool (a).
