Render Output!
Mar 2, 2013 8:38 PM
Hi all,
I am very much new to the forums. I am having problems with rendering in the right size. I have a project which has some clips that are of size 1920*1080. But some reason when I render it down, the real video playback just happens on the center of the screen. And on the render settings window I have made it perfectly sure that the render output matches the source attributes. Tried on with a variety of formats but unfortunately all came out with the same results. How do rectify this?
Please Advice.
Here is the image for reference. Instead of being fullscreen it is just on the center of the screen.
    Mar 3, 2013 8:09 AM   in reply to Sumesh Chandran
    Are you talking about rendering within Premiere Pro, or exporting out of Premiere Pro?
    Mar 3, 2013 9:07 AM   in reply to Sumesh Chandran
    Welcome to the forum.
    When you say:
    What player are you using to display this footage?
    Mar 3, 2013 10:07 AM   in reply to Sumesh Chandran
    Does your sequence match your video?
    Please NOTE that the PPro CS6 screen may look a bit different (I use CS5)
    For CS5 and later, the easy way to insure that your video and your project match
    See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
    -and a FAQ on sequence setting http://forums.adobe.com/message/3804341
    Mar 3, 2013 4:07 PM   in reply to Sumesh Chandran
    I am rendering within Premiere Pro.
    I used Adobe media player & VLC Media player
    Those are contradictory statements.  Rendering doesn't create a file for playback outside of PP, exporting does.
    The problem is likely that you have a settings mismatch.  Is the clip genuinely 1920 x 1080 with a PAR of 1.33, because that's very unusual.  It's either 1920 x 1080 with a 1.0 PAR, or it's 1440 x 1080 with a 1.33 PAR.
    Also, what are your sequence settings?
    Mar 3, 2013 4:11 PM   in reply to Sumesh Chandran
    The problem is the aspect ratio of the clip.
    1920x1080 can't be 1.33 it should read 1.0.
    1,33 is an aspect ratio used with clips that are 1440x1080.
    Mar 4, 2013 7:55 AM   in reply to Sumesh Chandran
    Is there any way to change the aspect ratio of the clip?
    You generally don't want to do that, otherwise you will alter the normally correct presentation of that clip.
    However, you might want to work in a different sequence.  Right click on a clip in the bin and select New Sequence from Clip.  This will create a sequence that properly matches your footage.  You can then remove the clip from the new sequence and copy/paste all the clips from the finished sequence into the new one.
