Lex91
Encore - CS6 vs Older Version (2006 Copy)  Encoding Quality Difference?
Mar 2, 2013 9:01 PM
I have an 2006 Copy of Encore for SD DVD's, will a new version have better quality encoding? Thank You
    Mar 3, 2013 12:36 AM   in reply to Lex91
    2006?  Is that CS2 or 3?
    Whatever, yes, the version of AME which comes with Premiere/Encore in CS6 gives much improved rersults for DVD, particularly if you have to downscale from HD/HDV.
    Mar 3, 2013 8:23 AM   in reply to Lex91
    Using CS5 http://forums.adobe.com/thread/652694 I have great results when going from AVCHD to a DVD
    Mar 3, 2013 10:04 AM   in reply to Lex91
    Too many variable for someone to "globally" say what will work for your DVD... or not
    Video with a lot of movement (a sporting event, for example) requires a higher bit rate than a video of someone standing still to give a speech
    The only way for you to know is to do as you say... run your own test
    Mar 4, 2013 8:34 AM   in reply to Lex91
    They both use the MainConcept encoder, so it's likely you won't be able to see much difference.
    For a real improvement, go the freeware route.
    HC Encoder for MPEG2
    http://www.bitburners.com/hc-encoder/
    Xvid4PSP for H.264 (version 5, not 6)
    http://www.videohelp.com/tools/XviD4PSP
