Kiki1008
Perfecting Hand Drawn Images
Mar 3, 2013 2:44 AM
Tags: #illustrator #live_trace #hand_drawn #edit_scanned_image
I am trying to turn hand drawn b&w monograms into vector images.  My hand drawn images are not perfect and need to have lines straightened, curves fixed, etc.  How can I make these changes once I have performed the Live Trace function?  Is there a way to do this automatically or do I have to use the smooth tool?  Are there other tools or functions that would be helpful?  Thanks so much!
    Mar 3, 2013 2:46 AM   in reply to Kiki1008
    If precision is the goal, it is often better to use the Pen Tool and manually trace rather than use any automated method.
    Mar 3, 2013 4:19 AM   in reply to Kiki1008
    Like Scott says, the Pen tool is your friend.
    If you use it you can control precisely where each anchor is positioned and produce perfect smooth curves.
    No automated trace can do this.
    Mar 3, 2013 8:23 AM   in reply to Kiki1008
    Contrary to marketing-driven misconception, the primary purpose of programs like Illustrator is not "automatic conversion" of raster images to vector-based paths (i.e.; autotracing).
    Bezier drawing programs are primarily all about  drawing accurate vector (math formula-based) paths deliberately. That necessarily means drawing them manually and knowingly.
    In other words, for your stated purpose, you should not be doing this by starting with autotracing at all. You shoud be using the various drawing tools to methodically construct the artwork paths manually. Yes, the quality of the results is dependent upon proficiency. That's just the way it is in vector-based drawing, just as it is in just about anything.
    Quality (including accuracy and economy) in vector-based drawing does not come from merely owning software, just as quality work on your car does not come from merely owning a wrench. In the vast majority of cases, using autotracing is just like a shadetree "mechanic" using a pair of pliers to turn a hex bolt. Both should make you cringe. Yeah, the pliers-wielding buffoon (and no, I'm not calling you a buffoon) may get the bolt to turn; and someone who never looks under the hood may never know the difference. But would you knowingly take your car back to such a "mechanic"?
    Forget autotracing. It's crap. It has no shape-recognition intelligence. In Illustrator, it doesn't even know an actual circle from any other "sort of roundish" curve. The same can be said for features like Smooth, Roughen, etc. No, they are not utterly useless. But they should be used with knowing discretion.
    Buckle down and learn to draw paths accurately, efficiently, and economically. It's not rocket science, but there is no instant substitute. The kind of task you are describing is the very kind  of work which serves best as learning exercises.
    JET
    Mar 3, 2013 10:59 PM   in reply to Kiki1008
    JET offers very helpful guidance. Though learning to draw precise paths can be time consuming, remember that practice makes perfect.
    I came across a tutorial about moving from a sketch to a finished vector illustration that outlines how to create shapes with the pen tool and using brushes. Find it here.
    I have also found the Width Tool to be extremely helpful in creating line variation. Below is a great video about how to use it.
    Good luck in your drawing endeavors!
