Gradient Stroke Blends
Mar 3, 2013 3:45 AM
Hi. I like the Gradient Mesh a lot and am wanting to break the mesh down to gradient strokes. I'm not able to do that. So I thought I would try to work around it by trying to blend two gradient strokes. The result is what appears to be an envelope and interestingly enough the image is close to the Gradient Mesh. But I am still unable to get the gradient strokes from expanding my object. Doesn't Illustrator have the feature to blend two gradient strokes?
    Mar 3, 2013 3:52 AM   in reply to scribbles2day
    You'll need to explain further.
    I can create 2 strokes with gradients and blend between them. Then expand the [b]object[/b] and get gradient strokes. The main restriction is that it appears all blend generated strokes have the "within stroke" applied and with the live blend, you can't change that regardless of how the original strokes are set.
    Mar 3, 2013 4:06 AM   in reply to scribbles2day
    There's something you're not realizing and explaining. The basic steps work....
    Mar 3, 2013 4:20 AM   in reply to scribbles2day
    Okay.. it seems that any gradient option other than "within" does not expand as it should. All blend steps are drawn with the "within" option and only the "within" option allows expanding.
    Looks like a bug or missing functionality. Nothing you can do about it until Adobe fixes it.
