Hi, I'm trying to create a large epub (for iPad) which will be fixed layout. This means that each page is a separate indd so that the css and xhtml can be individually changed as needed. However, the way in which Indesign handles the export to epub is by opening all of the files. It seems that the limit it can open is 137 files. So, the export 'skips' files. I'm running CS6 with the latest update 8.0.1.406 and have tried the 'fix' that was recently released, that was meant to open files to get essential information and then close them, but to no avail. Interestingly, I've tried to open more than 137 indd pages within Indesign, but it then denies access to any more files.
Now, I suppose I could make two books and join them together through altering the spine/manifest etc but it seems that this is going to be a bit of a problem for large designed books, not just children's books, where fixed layout is important. It woud be so much better if the entire workflow could be handled within Indesign. As it is there is still a lot of work to be done in Dreamweaver to change each page after export.
If anyone has found a solution to this, I'd be grateful if you would share it.
Many thanks
Jack
Macbook pro, Creative Suite 6
You may find this book by Pariah Burke "Creating Fixed-Layout eBooks,
ePublishing with InDesign" worthwhile reading: http://amzn.to/WBjwz1
Bob
I may well, but the title indicates that it is more about creating ebooks (I couldn't check the contents) than about Indesign's functionality. If there is a specific point in the book that solves this issue, I would be more than happy to purchase it. Does it? As my question really relates to Indesign's operation, I'm really hoping that someone with a far better knowledge of the program than I will help shed some light on the problem.
Jack
Hi, Jack.
Actually, the solution to your problem is easy: don't use separate INDDs. It's easy to create fixed-layout ebooks, with the required separate XHTML files, from one or several INDDs. Bob's right:
"Creating Fixed-Layout eBooks, ePublishing with InDesign" http://amzn.to/WBjwz1 will explain just how to do all that. It's about creating fixed-layout ebooks from within InDesign, just like my ePublishing with InDesign CS6 (http://abbrv.it/DigiPubID) is about creating all sorts of digital publications from within InDesign.
North America
Asia Pacific
