rfe_adobe_1
Droplet broken in Photoshop CS6
Mar 4, 2013 12:29 PM
Tags: #photoshop #eps #actions #cs6 #broken #droplets
Since switching to CS6 when I create an image resize action in Photoshop the action runs correctly but if I
create a droplet then the action makes the image width and height deminsions the same matching neither from
the action.
It makes a 2550 x 1880 image, that I'm trying to convert to 612 x 432 into a 512 x 512 image.  It also
seems to be having an issue with eps files, because when I open the same eps again and run the action
it adds a '-1' then '-2' then '-3' and so on, to the end of the name.
I've tried it on three Macs works the same on each one.  I'm try to convert .eps files created in illustrator to
.gifs for web preview.  I can make an action in Illustrator, but there's no droplet.  And if I save the files
in .ai then the action for the droplet won't make it past opening the files.  Even though suppress action
open prompts are turned off.
Is this broken or am I doing something wrong?  It is the same work flow I've been using since CS3, but does
not work anymore.
    Mar 4, 2013 8:27 PM   in reply to rfe_adobe_1
    It seems to work okay with both illy eps and ai files on windows using photoshop cs6, but the action i used may be different from what you have, so it might be best to post
    a screenshot of the action and the Create Droplet dialog with your settings.
