In elements 9.0, under PAPER SIZE options (for printing), there is no longer an option for panoramics (as there was in Ele 2.0! WHY?) I need to print over 19" (on 8.2" wide panoramic paper), and the largest paper sixe offered is 13"x 19". Can a CUSTOM size be set up beyond the standard paper sizes on Elements 9.0? thanks
In the Print dialog, there are various options for Print paper size, which range to 40 inches or more..
If you are not getting the exact size you want to print, make your image of the dimensions you need to print and select a paper( from Paper size) which might be larger than that size(which can be A0, A1, Overisize sizxes, etc..) and select "Actual Size" from Print Size.
print and remove the unwanted paper or poster.
Windows 7. (regrettably, to do an EndRun around this limitation, I tried
to download the olde Elelments 2.0. Would not download on 7)
In a message dated 3/5/2013 9:12:04 A.M. Eastern Standard Time,
forums_noreply@adobe.com writes:
Re: Custom paper size?
created by Barbara B. (http://forums.adobe.com/people/Barbara+B.) in
Photoshop Elements - View the full discussion
Thanks Swarnima,
Thank You, but Of the 19 Paper Size options in my 9.0, the largest overall
size is "A3" (w 23.375" long dimens). Regrettably, there is no A0, A1, or
Oversize sizes. Unless the "user defined" option allows me to go larger
,then Ele 9.0 appears not to allow printing over 23.375". Is "User Defined"
an option, and how would I set it up? There doesn't appear to be an
obvious procedure for this.
thanks
don
In a message dated 3/5/2013 6:47:00 P.M. Eastern Standard Time,
created by Swarnima (http://forums.adobe.com/people/Swarnima) in
North America
Asia Pacific
