A group and I have been building an e-book in flash and we are all very new to flash and autoscript.
We have come across some issues we are having a very hard time trying to fix:
*We set up a button/symbol that plays audio. Everytime you click on it repeatedly, the audio is playing all at once until they are are all finished. we're trying to find out how to start the audio over after each press.
*Also, the sound resulting from the button press continues even after you switch to the next page, until the audio track is done.
*For some reason, some of the buttons/symbols need to be pressed and held for them to activate and maintain their action or else they go back to being the unpressed default.
I'm having the same propblem where all the audio plays when loading.
Each Frame has it's own code for the audio when the frame loads and the buttons on the page:
Here's the code style for each frame:
stop();
letterA_btn.addEventListener(MouseEvent.CLICK, onLetterA);
father_btn.addEventListener(MouseEvent.CLICK, onFather);
people_btn.addEventListener(MouseEvent.CLICK, onPeople);
house1_btn.addEventListener(MouseEvent.CLICK, onHouse);
Here is the code for first frame;
stop();
import flash.media.Sound;
import flash.media.SoundMixer;
import flash.net.SharedObject;
var hiddenOptions:Boolean = true;
/**************SETUP**************/
optionsMenu.visible = false;
//**************OPTIONS MENU**************/
stage.addEventListener(KeyboardEvent.KEY_UP, optionsKey);
function optionsKey(event:KeyboardEvent):void
setChildIndex(optionsMenu,numChildren-1);
optionsMenu.visible = true;
optionsMenu.addEventListener(MouseEvent.CLICK, exitApp);
function exitApp(event:MouseEvent):void {
("exitApp");
NativeApplication.nativeApplication.exit(0);
next_btn.addEventListener(MouseEvent.CLICK,onNext);
function onNext(event:MouseEvent) {
nextFrame();
back_btn.addEventListener(MouseEvent.CLICK,onBack);
function onBack(event:MouseEvent) {
prevFrame();
function buttonClick(event:MouseEvent):void {
gotoAndStop(event.target.name);
btn_intro.enabled=true;
btn_1.enabled=true;
btn_2.enabled=true;
btn_3.enabled=true;
btn_4.enabled=true;
btn_5.enabled=true;
btn_6.enabled=true;
btn_7.enabled=true;
btn_8.enabled=true;
btn_9.enabled=true;
btn_10.enabled=true;
btn_11.enabled=true;
btn_12.enabled=true;
btn_13.enabled=true;
btn_14.enabled=true;
btn_15.enabled=true;
btn_16.enabled=true;
btn_17.enabled=true;
btn_18.enabled=true;
btn_19.enabled=true;
btn_20.enabled=true;
btn_21.enabled=true;
btn_22.enabled=true;
btn_23.enabled=true;
btn_24.enabled=true;
btn_25.enabled=true;
btn_26.enabled=true;
btn_27.enabled=true;
btn_28.enabled=true;
btn_29.enabled=true;
btn_30.enabled=true;
btn_31.enabled=true;
btn_32.enabled=true;
btn_33.enabled=true;
btn_34.enabled=true;
btn_35.enabled=true;
btn_36.enabled=true;
btn_37.enabled=true;
btn_38.enabled=true;
btn_39.enabled=true;
btn_40.enabled=true;
btn_41.enabled=true;
btn_42.enabled=true;
btn_43.enabled=true;
btn_44.enabled=true;
btn_45.enabled=true;
event.target.enabled=false;
btn_intro.addEventListener(MouseEvent.CLICK,buttonClick);
btn_1.addEventListener(MouseEvent.CLICK,buttonClick);
btn_2.addEventListener(MouseEvent.CLICK,buttonClick);
btn_3.addEventListener(MouseEvent.CLICK,buttonClick);
btn_4.addEventListener(MouseEvent.CLICK,buttonClick);
btn_5.addEventListener(MouseEvent.CLICK,buttonClick);
btn_6.addEventListener(MouseEvent.CLICK,buttonClick);
btn_7.addEventListener(MouseEvent.CLICK,buttonClick);
btn_8.addEventListener(MouseEvent.CLICK,buttonClick);
btn_9.addEventListener(MouseEvent.CLICK,buttonClick);
btn_10.addEventListener(MouseEvent.CLICK,buttonClick);
btn_11.addEventListener(MouseEvent.CLICK,buttonClick);
btn_12.addEventListener(MouseEvent.CLICK,buttonClick);
btn_13.addEventListener(MouseEvent.CLICK,buttonClick);
btn_14.addEventListener(MouseEvent.CLICK,buttonClick);
btn_15.addEventListener(MouseEvent.CLICK,buttonClick);
btn_16.addEventListener(MouseEvent.CLICK,buttonClick);
btn_17.addEventListener(MouseEvent.CLICK,buttonClick);
btn_18.addEventListener(MouseEvent.CLICK,buttonClick);
btn_19.addEventListener(MouseEvent.CLICK,buttonClick);
btn_20.addEventListener(MouseEvent.CLICK,buttonClick);
btn_21.addEventListener(MouseEvent.CLICK,buttonClick);
btn_22.addEventListener(MouseEvent.CLICK,buttonClick);
btn_23.addEventListener(MouseEvent.CLICK,buttonClick);
btn_24.addEventListener(MouseEvent.CLICK,buttonClick);
btn_25.addEventListener(MouseEvent.CLICK,buttonClick);
btn_26.addEventListener(MouseEvent.CLICK,buttonClick);
btn_27.addEventListener(MouseEvent.CLICK,buttonClick);
btn_28.addEventListener(MouseEvent.CLICK,buttonClick);
btn_29.addEventListener(MouseEvent.CLICK,buttonClick);
btn_30.addEventListener(MouseEvent.CLICK,buttonClick);
btn_31.addEventListener(MouseEvent.CLICK,buttonClick);
btn_32.addEventListener(MouseEvent.CLICK,buttonClick);
btn_33.addEventListener(MouseEvent.CLICK,buttonClick);
btn_34.addEventListener(MouseEvent.CLICK,buttonClick);
btn_35.addEventListener(MouseEvent.CLICK,buttonClick);
btn_36.addEventListener(MouseEvent.CLICK,buttonClick);
btn_37.addEventListener(MouseEvent.CLICK,buttonClick);
btn_38.addEventListener(MouseEvent.CLICK,buttonClick);
btn_39.addEventListener(MouseEvent.CLICK,buttonClick);
btn_40.addEventListener(MouseEvent.CLICK,buttonClick);
btn_41.addEventListener(MouseEvent.CLICK,buttonClick);
btn_42.addEventListener(MouseEvent.CLICK,buttonClick);
btn_43.addEventListener(MouseEvent.CLICK,buttonClick);
btn_44.addEventListener(MouseEvent.CLICK,buttonClick);
btn_45.addEventListener(MouseEvent.CLICK,buttonClick);
var BTN1:Sound = new Sound();
BTN1.load(new URLRequest("sounds/BTN1.mp3"));
BTN1.play();
function onBTN_1(e:MouseEvent):void{
SoundMixer.stopAll();
BTN1.play();
var BTN2:Sound = new Sound();
BTN2.load(new URLRequest("sounds/BTN2.mp3"));
BTN2.play();
function onBTN_2(e:MouseEvent):void{
BTN2.play();
var BTN3:Sound = new Sound();
BTN3.load(new URLRequest("sounds/BTN3.mp3"));
BTN3.play();
function onBTN_3(e:MouseEvent):void{
BTN3.play();
var BTN4:Sound = new Sound();
BTN4.load(new URLRequest("sounds/BTN4.mp3"));
BTN4.play();
function onBTN_4(e:MouseEvent):void{
BTN4.play();
var BTN5:Sound = new Sound();
BTN5.load(new URLRequest("sounds/BTN5.mp3"));
BTN5.play();
function onBTN_5(e:MouseEvent):void{
BTN5.play();
var BTN6:Sound = new Sound();
BTN6.load(new URLRequest("sounds/BTN6.mp3"));
BTN6.play();
function onBTN_6(e:MouseEvent):void{
BTN6.play();
var BTN7:Sound = new Sound();
BTN7.load(new URLRequest("sounds/BTN7.mp3"));
BTN7.play();
function onBTN_7(e:MouseEvent):void{
BTN7.play();
var BTN8:Sound = new Sound();
BTN8.load(new URLRequest("sounds/BTN8.mp3"));
BTN8.play();
function onBTN_8(e:MouseEvent):void{
BTN8.play();
var BTN9:Sound = new Sound();
BTN9.load(new URLRequest("sounds/BTN9.mp3"));
BTN9.play();
function onBTN_9(e:MouseEvent):void{
BTN9.play();
var BTN10:Sound = new Sound();
BTN10.load(new URLRequest("sounds/BTN10.mp3"));
BTN10.play();
function onBTN_10(e:MouseEvent):void{
BTN10.play();
var BTN11:Sound = new Sound();
BTN11.load(new URLRequest("sounds/BTN11.mp3"));
BTN11.play();
function onBTN_11(e:MouseEvent):void{
BTN11.play();
var BTN12:Sound = new Sound();
BTN12.load(new URLRequest("sounds/BTN12.mp3"));
BTN12.play();
function onBTN_12(e:MouseEvent):void{
BTN12.play();
var BTN13:Sound = new Sound();
BTN13.load(new URLRequest("sounds/BTN13.mp3"));
BTN13.play();
function onBTN_13(e:MouseEvent):void{
BTN13.play();
var BTN14:Sound = new Sound();
BTN14.load(new URLRequest("sounds/BTN14.mp3"));
BTN14.play();
function onBTN_14(e:MouseEvent):void{
BTN14.play();
var BTN15:Sound = new Sound();
BTN15.load(new URLRequest("sounds/BTN15.mp3"));
BTN15.play();
function onBTN_15(e:MouseEvent):void{
BTN15.play();
var BTN16:Sound = new Sound();
BTN16.load(new URLRequest("sounds/BTN16.mp3"));
BTN16.play();
function onBTN_16(e:MouseEvent):void{
BTN16.play();
var BTN17:Sound = new Sound();
BTN17.load(new URLRequest("sounds/BTN17.mp3"));
BTN17.play();
function onBTN_17(e:MouseEvent):void{
BTN17.play();
var BTN18:Sound = new Sound();
BTN18.load(new URLRequest("sounds/BTN18.mp3"));
BTN18.play();
function onBTN_18(e:MouseEvent):void{
BTN18.play();
var BTN19:Sound = new Sound();
BTN19.load(new URLRequest("sounds/BTN19.mp3"));
BTN19.play();
function onBTN_19(e:MouseEvent):void{
BTN19.play();
var BTN20:Sound = new Sound();
BTN20.load(new URLRequest("sounds/BTN20.mp3"));
BTN20.play();
function onBTN_20(e:MouseEvent):void{
BTN20.play();
var BTN21:Sound = new Sound();
BTN21.load(new URLRequest("sounds/BTN21.mp3"));
BTN21.play();
function onBTN_21(e:MouseEvent):void{
BTN21.play();
var BTN22:Sound = new Sound();
BTN22.load(new URLRequest("sounds/BTN22.mp3"));
BTN22.play();
function onBTN_22(e:MouseEvent):void{
BTN22.play();
var BTN23:Sound = new Sound();
BTN23.load(new URLRequest("sounds/BTN23.mp3"));
BTN23.play();
function onBTN_23(e:MouseEvent):void{
BTN23.play();
var BTN24:Sound = new Sound();
BTN24.load(new URLRequest("sounds/BTN24.mp3"));
BTN24.play();
function onBTN_24(e:MouseEvent):void{
BTN24.play();
var BTN25:Sound = new Sound();
BTN25.load(new URLRequest("sounds/BTN25.mp3"));
BTN25.play();
function onBTN_25(e:MouseEvent):void{
BTN25.play();
var BTN26:Sound = new Sound();
BTN26.load(new URLRequest("sounds/BTN26.mp3"));
BTN26.play();
function onBTN_26(e:MouseEvent):void{
BTN26.play();
var BTN27:Sound = new Sound();
BTN27.load(new URLRequest("sounds/BTN27.mp3"));
BTN27.play();
function onBTN_27(e:MouseEvent):void{
BTN27.play();
var BTN28:Sound = new Sound();
BTN28.load(new URLRequest("sounds/BTN28.mp3"));
BTN28.play();
function onBTN_28(e:MouseEvent):void{
BTN28.play();
var BTN29:Sound = new Sound();
BTN29.load(new URLRequest("sounds/BTN29.mp3"));
BTN29.play();
function onBTN_29(e:MouseEvent):void{
BTN29.play();
var BTN30:Sound = new Sound();
BTN30.load(new URLRequest("sounds/BTN30.mp3"));
BTN30.play();
function onBTN_30(e:MouseEvent):void{
BTN30.play();
var BTN31:Sound = new Sound();
BTN31.load(new URLRequest("sounds/BTN31.mp3"));
BTN31.play();
function onBTN_31(e:MouseEvent):void{
BTN31.play();
var BTN32:Sound = new Sound();
BTN32.load(new URLRequest("sounds/BTN32.mp3"));
BTN32.play();
function onBTN_32(e:MouseEvent):void{
BTN32.play();
var BTN33:Sound = new Sound();
BTN33.load(new URLRequest("sounds/BTN33.mp3"));
BTN20.play();
function onBTN_33(e:MouseEvent):void{
BTN33.play();
var BTN34:Sound = new Sound();
BTN34.load(new URLRequest("sounds/BTN20.mp3"));
BTN34.play();
function onBTN_34(e:MouseEvent):void{
BTN34.play();
var BTN35:Sound = new Sound();
BTN35.load(new URLRequest("sounds/BTN35.mp3"));
BTN35.play();
function onBTN_35(e:MouseEvent):void{
BTN35.play();
var BTN36:Sound = new Sound();
BTN36.load(new URLRequest("sounds/BTN36.mp3"));
BTN36.play();
function onBTN_36(e:MouseEvent):void{
BTN36.play();
var BTN37:Sound = new Sound();
BTN37.load(new URLRequest("sounds/BTN37.mp3"));
BTN37.play();
function onBTN_37(e:MouseEvent):void{
BTN37.play();
var BTN38:Sound = new Sound();
BTN38.load(new URLRequest("sounds/BTN38.mp3"));
BTN38.play();
function onBTN_38(e:MouseEvent):void{
BTN38.play();
var BTN39:Sound = new Sound();
BTN39.load(new URLRequest("sounds/BTN39.mp3"));
BTN39.play();
function onBTN_39(e:MouseEvent):void{
BTN39.play();
var BTN40:Sound = new Sound();
BTN40.load(new URLRequest("sounds/BTN40.mp3"));
BTN40.play();
function onBTN_40(e:MouseEvent):void{
BTN40.play();
var BTN41:Sound = new Sound();
BTN41.load(new URLRequest("sounds/BTN41.mp3"));
BTN41.play();
function onBTN_41(e:MouseEvent):void{
BTN41.play();
var BTN42:Sound = new Sound();
BTN42.load(new URLRequest("sounds/BTN42.mp3"));
BTN42.play();
function onBTN_42(e:MouseEvent):void{
BTN42.play();
var BTN43:Sound = new Sound();
BTN43.load(new URLRequest("sounds/BTN43.mp3"));
BTN43.play();
function onBTN_43(e:MouseEvent):void{
BTN43.play();
var BTN44:Sound = new Sound();
BTN44.load(new URLRequest("sounds/BTN44.mp3"));
BTN44.play();
function onBTN_44(e:MouseEvent):void{
BTN44.play();
var BTN45:Sound = new Sound();
BTN45.load(new URLRequest("sounds/BTN45.mp3"));
BTN45.play();
function onBTN_45(e:MouseEvent):void{
BTN45.play();
btn_1.addEventListener(MouseEvent.CLICK, onBTN_1);
btn_2.addEventListener(MouseEvent.CLICK, onBTN_2);
btn_3.addEventListener(MouseEvent.CLICK, onBTN_3);
btn_4.addEventListener(MouseEvent.CLICK, onBTN_4);
btn_5.addEventListener(MouseEvent.CLICK, onBTN_5);
btn_6.addEventListener(MouseEvent.CLICK, onBTN_6);
btn_7.addEventListener(MouseEvent.CLICK, onBTN_7);
btn_8.addEventListener(MouseEvent.CLICK, onBTN_8);
btn_9.addEventListener(MouseEvent.CLICK, onBTN_9);
btn_10.addEventListener(MouseEvent.CLICK, onBTN_10);
btn_11.addEventListener(MouseEvent.CLICK, onBTN_11);
btn_12.addEventListener(MouseEvent.CLICK, onBTN_12);
btn_13.addEventListener(MouseEvent.CLICK, onBTN_13);
btn_14.addEventListener(MouseEvent.CLICK, onBTN_14);
btn_15.addEventListener(MouseEvent.CLICK, onBTN_15);
btn_16.addEventListener(MouseEvent.CLICK, onBTN_16);
btn_17.addEventListener(MouseEvent.CLICK, onBTN_17);
btn_18.addEventListener(MouseEvent.CLICK, onBTN_18);
btn_19.addEventListener(MouseEvent.CLICK, onBTN_19);
btn_20.addEventListener(MouseEvent.CLICK, onBTN_20);
btn_21.addEventListener(MouseEvent.CLICK, onBTN_21);
btn_22.addEventListener(MouseEvent.CLICK, onBTN_22);
btn_23.addEventListener(MouseEvent.CLICK, onBTN_23);
btn_24.addEventListener(MouseEvent.CLICK, onBTN_24);
btn_25.addEventListener(MouseEvent.CLICK, onBTN_25);
btn_26.addEventListener(MouseEvent.CLICK, onBTN_26);
btn_27.addEventListener(MouseEvent.CLICK, onBTN_27);
btn_28.addEventListener(MouseEvent.CLICK, onBTN_28);
btn_29.addEventListener(MouseEvent.CLICK, onBTN_29);
btn_30.addEventListener(MouseEvent.CLICK, onBTN_30);
btn_31.addEventListener(MouseEvent.CLICK, onBTN_31);
btn_32.addEventListener(MouseEvent.CLICK, onBTN_32);
btn_33.addEventListener(MouseEvent.CLICK, onBTN_33);
btn_34.addEventListener(MouseEvent.CLICK, onBTN_34);
btn_35.addEventListener(MouseEvent.CLICK, onBTN_35);
btn_36.addEventListener(MouseEvent.CLICK, onBTN_36);
btn_37.addEventListener(MouseEvent.CLICK, onBTN_37);
btn_38.addEventListener(MouseEvent.CLICK, onBTN_38);
btn_39.addEventListener(MouseEvent.CLICK, onBTN_39);
btn_40.addEventListener(MouseEvent.CLICK, onBTN_40);
btn_41.addEventListener(MouseEvent.CLICK, onBTN_41);
btn_42.addEventListener(MouseEvent.CLICK, onBTN_42);
btn_43.addEventListener(MouseEvent.CLICK, onBTN_43);
btn_44.addEventListener(MouseEvent.CLICK, onBTN_44);
btn_45.addEventListener(MouseEvent.CLICK, onBTN_45);
//btn1
var uhoh:Sound = new Sound();
uhoh.load(new URLRequest("sounds/uhoh.mp3"));
uhoh.play();
function onUh_Oh(e:MouseEvent):void{
uhoh.play();
var house:Sound = new Sound();
house.load(new URLRequest("sounds/house.mp3"));
uhoh.play();
function onHouse(e:MouseEvent):void{
house.play();
var sleep:Sound = new Sound();
sleep.load(new URLRequest("sounds/sleep.mp3"));
sleep.play();
function onSleep(e:MouseEvent):void{
sleep.play();
//btn2
var letterA:Sound = new Sound();
letterA.load(new URLRequest("sounds/letterA.mp3"));
letterA.play();
function onLetterA(e:MouseEvent):void{
letterA.play();
var father:Sound = new Sound();
father.load(new URLRequest("sounds/father.mp3"));
father.play();
function onFather(e:MouseEvent):void{
father.play();
You really just need to post the relevant code or if you need to paste this much, please use a service like pastebin.com.
As for why sounds are playing right off the start, you're telling them to. Just the last bit of code states it here:
father.play();
father.play();
I didn't scan all that code without indenting or syntax coloring but I didn't notice anything running "onFather", perhaps it's a button way above. However way before that's ever triggered via MouseEvent, you're already playing the sound immediately after loading it (in bold above). Why are you playing all of these after loading?
North America
Asia Pacific
