vbalmori
"Class" for Exporting for ActionScript not accessible
Mar 4, 2013 10:36 PM
I am trying to export some audio files with Sound Properties > Export for ActionScript. However, for some reason the "Class" box is greyed out and unaccessible. I've tried out a number of different files: .mp3, .wav,  .aif, but Class is still greyed out.
What is the problem? Is there some sort of workaround?
    Mar 5, 2013 6:12 AM   in reply to vbalmori
    What version of Flash are you using? What's the bitrate of the sound?
    I assume it is in the library and you are doing the following:  Right Click -> Properties -> ActionScript -> Trying to check the "Export for ActionScript" checkbox and it is grayed out?
    What you are doing should definitely work as far as I know because I am pretty sure the sound doesn't even import into Flash if the bitrate is too high but still something to check.
  • kglad
    Jul 21, 2002
    Mar 5, 2013 6:14 AM   in reply to vbalmori
    i'm not sure where you see Sound Properties but you should be right clicking your sound in the library panel>click properties>tick export for actionscript and the class and base class fields should be filed in and editable.
  • kglad
    Jul 21, 2002
    Mar 5, 2013 12:35 PM   in reply to vbalmori
    no.  the coding will be substantially different for as2.
    to start, you'll need to use a linkage id (eg, soundID) for your sound, not a class name.
    then you'll need to apply attachSound to a sound instance.
    var s:Sound=new Sound();
    s.attachSound("soundID");
    s.start();
    and then the differences continue:
  • kglad
    Jul 21, 2002
    Mar 5, 2013 1:16 PM   in reply to vbalmori
    stopAllSounds() will stop all sounds, no matter how they started, that are playing at the time it executes.  however, it does not stop a sound from starting and continuing to play after it executes.
