So I've read multiple discissons on XDCAM but have yet to find a solution to my particular problem.
I have the raw mp4 files from xdcam which was improperly copied off (without the file structre) the memory card by the person before me. The original memory cards are gone so there's no way to re capture. Premier cs6 and FCP both can't read the files, Premier has a "no video or audio streams" Error.
I have tried to change the container to .mxf but then I get a "general error" on import. I know you can get a codec from Calibrated{Q} but I can't afford the $150 price tag. Is it as simple as me missing a codec or is there something I can do to the footage to make it readable by Premier OR FCP (I can then transcode to an intermediate codec)
Does anyone have any suggestions?
Nikko
The media Info on the files is:
General
Complete name : E:\Work - 2\Masters Exibition\Lisa_folder\Footage_lisa\TAKE_2\Lisa_take2_SONY_EX3\288_044 8_01\288_0448_01.MP4
Format : MPEG-4
Commercial name : XDCAM EX 35
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 190 MiB
Duration : 43s 640ms
Overall bit rate mode : Variable
Overall bit rate : 36.5 Mbps
Encoded date : UTC 2013-02-18 00:07:57
Tagged date : UTC 2013-03-05 05:25:24
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Codec ID : 61
Bit rate mode : Variable
Bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.675
Stream size : 182 MiB (96%)
Language : English
Tagged date : UTC 2013-02-18 00:07:57
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Codec ID : twos
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 7.99 MiB (4%)
Language : English
North America
Asia Pacific
