losing image quality
Mar 4, 2013 9:48 PM
Tags: #image #quality
I am working in Illustrator CS5.  I have a jpg I am placing into an illustrator file and for some reason I am losing major quality and I can't figure out why.  I have done this for years with no problem, but for some reason this photo has problems. I have opened the same file in photoshop and quality is great, size is much larger than need and 300 dpi.  Any ideas what could be happening?
    Mar 4, 2013 11:35 PM   in reply to shjaredarj
    It has a color profile attached and AI is converting it quite likely...
    Mylenium
    Mar 5, 2013 10:49 AM   in reply to shjaredarj
    Some screen shots would be nice.  Something that shows what you mean by "losing quality".  Your applications should be optimized and color managed to honor profiles ( or not...your call ). And, I'd love to know how you decided the image quality reduced in Illustrator.  Did you view it using a viewer?  I need more information in order to make any type of recommendation.
    Mar 5, 2013 1:33 PM   in reply to shjaredarj
    - how is your color management set up? in both apps
    - what color space are you working in in Photoshop?
    - and in Illustrator?
    - do you link or embed the images?
    Mar 5, 2013 2:13 PM   in reply to shjaredarj
    First, in Photoshop, Save the file as a targa file and if you can convert it to either lab colors or rgb (without lossing color quality), if it is CMYK. Then save it again as something other than a jpeg. Then close it and then re-open it. Then save it again as a jpeg. This will hopefully remove the color profile.
    Mar 7, 2013 9:49 PM   in reply to shjaredarj
    hmm... sorry about that, the way I understood the problem, that should have worked as I have had similar issues in the past. Is there anyway to remove the color profile manually?
    Mar 9, 2013 2:45 PM   in reply to shjaredarj
    Yes, that is correct, just keep the jpeg and get rid of the rest.
    Mar 9, 2013 3:02 PM   in reply to shjaredarj
    Oh Yes, sorry, absolutely that can be a problem... I understand it hasn't happened before however some images don't interpolate very well... Remeber to try to keep your resolution clos to the final size at the appropriate resolution.
