Mich_lou
COUNT DOWN TIMER
Mar 5, 2013 5:07 AM
Tags: #timer #countdown
Hello Community,
I really need your help in creating a count down timer for my site. I want to create a countdown timer similar to this one HERE for my homepage, however it seems like I can't set it up right. Please guide me on what I should do first. So far, I have created an index.html page (where I waould like it to be) and its still intact without any changes in respect to the countdown timer.
What am  I supposed to do now, do I need to create a java file on which I need to paste the code  on or I have to paste the code in my index.html code? I'm also confused with the code, is it jquery, html or both.
Please advise or help.
Thank You.
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Mar 5, 2013 5:24 AM   in reply to Mich_lou
    Well.
    This should go into your CSS file - name it countdown.css:
    div#clock { color: white; margin: 20px auto; width: 600px; overflow: hidden; text-align: center; }
    div#clock p { background: #333; float: left; height: 88px; width: 88px; }
    div#clock p span { display: block; font-size: 50px; font-weight: bold; padding: 5px 0 0; }
    div#clock div.space { color: #ccc; display: block; line-height: 1.7em; font-size: 50px; float: left; height: 88px; width: 30px; }
    div.multi_clock{ border: 1px solid #666; color: #333; float: left; margin: 10px; padding: 5px; }
    This, into the <head> section of your HTML file:
    <link rel="stylesheet" type="text/css" href="countdown.css">
    <script src="jquery.countdown.js" type="text/javascript" charset="utf-8"></script>
    <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js" type="text/javascript" charset="utf-8"></script>
    <script type="text/javascript" charset="utf-8">
    // Javascript
    $(function() {
      var currentDate = new Date();
      $('div#clock').countdown(15 * 24 * 60 * 60 * 1000 + currentDate.valueOf(), function(event) {
        $this = $(this);
        switch(event.type) {
          case "seconds":
          case "minutes":
          case "hours":
          case "days":
          case "weeks":
          case "daysLeft":
            $this.find('span#'+event.type).html(event.value);
            break;
          case "finished":
            $this.fadeTo('slow', .5);
            break;
    </script>
    Most important part: The red highlights on the code above:
    • div#clock is nothing but the target DIV ID where the clock will show. The HTML will have a <div id="clock"> in this scenario. Notice the HTML code below.
    • 15 * 24 * 60 * 60 - Days x Hours x Minutes x Seconds - Modify this to whatever value you want. For example, for 7 days, you will have 7 * 24 * 60 * 60
    Put this into a new file called jquery.countdown.js (JavaScript file):
    * jQuery The Final Countdown plugin v1.0.0 beta
    * http://github.com/hilios/jquery.countdown
    * Copyright (c) 2011 Edson Hilios
    * Permission is hereby granted, free of charge, to any person obtaining
    * a copy of this software and associated documentation files (the
    * "Software"), to deal in the Software without restriction, including
    * without limitation the rights to use, copy, modify, merge, publish,
    * distribute, sublicense, and/or sell copies of the Software, and to
    * permit persons to whom the Software is furnished to do so, subject to
    * the following conditions:
    * The above copyright notice and this permission notice shall be
    * included in all copies or substantial portions of the Software.
    * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
    * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
    * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
    * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
    * LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
    * OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
    * WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    (function($) {
      $.fn.countdown = function(toDate, callback) {
        var handlers = ['seconds', 'minutes', 'hours', 'days', 'weeks', 'daysLeft'];
        function delegate(scope, method) {
          return function() { return method.call(scope) }
        return this.each(function() {
          // Convert
          if(!(toDate instanceof Date)) {
            if(String(toDate).match(/^[0-9]*$/)) {
              toDate = new Date(toDate);
            } else if( toDate.match(/([0-9]{1,2})\/([0-9]{1,2})\/([0-9]{2,4})\s([0-9]{1,2})\ :([0-9]{2})\:([0-9]{2})/) ||
                toDate.match(/([0-9]{2,4})\/([0-9]{1,2})\/([0-9]{1,2})\s([0-9]{1,2})\ :([0-9]{2})\:([0-9]{2})/)
            } else if(toDate.match(/([0-9]{1,2})\/([0-9]{1,2})\/([0-9]{2,4})/) ||
                      toDate.match(/([0-9]{2,4})\/([0-9]{1,2})\/([0-9]{1,2})/)
            } else {
              throw new Error("Doesn't seen to be a valid date object or string")
          var $this = $(this),
              values = {},
              lasting = {},
              interval = $this.data('countdownInterval'),
              currentDate = new Date(),
              secondsLeft = Math.floor((toDate.valueOf() - currentDate.valueOf()) / 1000);
          function triggerEvents() {
            secondsLeft--;
            if(secondsLeft < 0) {
              secondsLeft = 0;
            lasting = {
              seconds : secondsLeft % 60,
              minutes : Math.floor(secondsLeft / 60) % 60,
              hours   : Math.floor(secondsLeft / 60 / 60) % 24,
              days    : Math.floor(secondsLeft / 60 / 60 / 24),
              weeks   : Math.floor(secondsLeft / 60 / 60 / 24 / 7),
              daysLeft: Math.floor(secondsLeft / 60 / 60 / 24) % 7
            for(var i=0; i<handlers.length; i++) {
              var eventName = handlers[i];
              if(values[eventName] != lasting[eventName]) {
                values[eventName] = lasting[eventName];
                dispatchEvent(eventName);
            if(secondsLeft == 0) {
              stop();
              dispatchEvent('finished');
          triggerEvents();
          function dispatchEvent(eventName) {
            var event = $.Event(eventName);
            event.date  = new Date(new Date().valueOf() + secondsLeft);
            event.value = values[eventName] || "0";
            event.toDate = toDate;
            event.lasting = lasting;
            switch(eventName) {
              case "seconds":
              case "minutes":
              case "hours":
                event.value = event.value < 10 ? '0'+event.value.toString() : event.value.toString();
                break;
              default:
                if(event.value) {
                  event.value = event.value.toString();
                break;
            callback.call($this, event);
          $this.bind('remove', function() {
            stop(); // If the selector is removed clear the interval for memory sake!
            dispatchEvent('removed');
          function stop() {
            clearInterval(interval);
          function start() {
            $this.data('countdownInterval', setInterval(delegate($this, triggerEvents), 1000));
            interval = $this.data('countdownInterval');
          if(interval) stop();
          start();
      // Wrap the remove method to trigger an event when called
      var removeEvent = new $.Event('remove'),
          removeFunction = $.fn.remove;
      $.fn.remove = function() {
        $(this).trigger(removeEvent);
        return removeFunction.apply(this, arguments);
    })(jQuery);
    This should come in the <body> section of your HTML page - wherever you want the timer to appear:
    <div id="clock">
      <p>
        <span id="weeks"></span>
        Weeks
      </p>
      <div class="space">:</div>
      <p>
        <span id="daysLeft"></span>
        Days
      </p>
      <p>
        <span id="hours"></span>
        Hours
      </p>
      <p>
        <span id="minutes"></span>
        Minutes
      </p>
      <p>
        <span id="seconds"></span>
        Seconds
      </p>
    </div>
    Save it. Run it.
    Oct 15, 2010
    Mar 5, 2013 5:29 AM   in reply to Sudarshan Thiagarajan
    Out of curiousity, there's a much more comprehensive, customizable timer if you're looking for alternatives: http://keith-wood.name/countdown.html
    Mar 5, 2013 5:50 AM   in reply to Sudarshan Thiagarajan
    @Mich_lou, just to close the loop, it's JavaScript, not Java. Those two are about as different as fish and bicycles (to paraphrase a well-known author).
    Oct 15, 2010
    Mar 5, 2013 9:46 AM   in reply to Mich_lou
    My bad. The order of calling for the jQuery library from CDN and using the actual script was flipped, thereby causing a 'null' display.
    Find these lines in your HTML code:
    Change to this:
    Notice your code was missing a < less then sign before link rel. Added that. Plus, I've flipped 2nd and 3rd lines - we have to first call the jquery library before running our script.
    Try it out now.
