Hi.
I've installed Photoshop CS6 on my Macbook Pro Retina i7 with 8gb of RAM. Running latest version of OSX Mountain Lion.
The system is obviously 64bit, as is the hardware. In the spashscreen of PS CS6, it says x64, so I know it's not running in 32bit.
Nonetheless, I have only got 1829Mb indicated as "available Ram". Why can't PS "see" the other 6Gigs?
When selecting the PS.app in "programs", and getting info, there is no option about 32 or 64bit to be found.
I think I'm missing something, but can anybody explain what?
Tx in advance,
Peter
Hi Chris,
Can't explain what happened, but as I checked the Sytem Log info, the amount of RAM used by photoshop fluctuates ??! I entered two occasions (1) and (2), but I've seen it at 2Gb and less as well...
Same in preferences. I can't say it's ever the same...
I must say that I did copy the plug-ins folder from CS5 to CS6 blindly, in order to keep the plugins. In the beginning it stated that some of the plugins couldn't be loaded, so I erased them from the plug-ins folder, and that seemed to work.
On the other hand, since I posted my first request, I didn't do anything in order to change the behavior of CS6.
I have Lightroom 4 open all the time with a library of approx. 5Gb
Maybe this has an influence on things?
I hope you can figure this out.
Adobe Photoshop Version: 13.0.4 (13.0.4 20130104.r.28 2013/01/04:21:00:00) x64
Operating System: Mac OS 10.8.2
System architecture: Intel CPU Family:6, Model:58, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2300 MHz
(1)
Built-in memory: 8192 MB
Free memory: 5584 MB
Memory available to Photoshop: 5890 MB
Memory used by Photoshop: 100 %
Image tile size: 1024K
Image cache levels: 4
(2)
Free memory: 4432 MB
Memory available to Photoshop: 4837 MB
(3)
Free memory: 4848 MB
Memory available to Photoshop: 5106 MB
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenCL Version: 1.2 (Sep 20 2012 17:42:28)
OpenGL Version: 2.1
Video Rect Texture Size: 16384
OpenGL Memory: 982 MB
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: NVIDIA GeForce GT 650M OpenGL Engine
Display: 2
High DPI Monitor
Display Depth: 32
Display Bounds: top=180, left=1920, bottom=1080, right=3360
Video Renderer ID: 16918087
Video Card Memory: 1024 MB
Display: 1
Main Display
Display Depth: 32
Display Bounds: top=0, left=0, bottom=1080, right=1920
Serial number: 91199291645021233852
Application folder: /Applications/Adobe Photoshop CS6/
Photoshop scratch has async I/O enabled
Scratch volume(s):
SSD LIGHTROOM 256GB, 238,2G, 179,0G free
Required Plug-ins folder: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/
Primary Plug-ins folder: /Applications/Adobe Photoshop CS6/Plug-ins/
Additional Plug-ins folder: not set
Installed components:
adbeape.framework adbeape 3.3.8.19346 66.1025012
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.2.29.18602 66.490082
adobe_caps.framework adobe_caps 6.0.29.0 1.276181
AdobeACE.framework AdobeACE 2.19.18.20743 66.507768
AdobeAGM.framework AdobeAGM 4.26.20.20743 66.507768
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.7.101.18636 66.26830
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
AdobeBIB.framework AdobeBIB 1.2.02.20743 66.507768
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 66.507768
AdobeCoolType.framework AdobeCoolType 5.10.33.20743 66.507768
AdobeCrashReporter.framework AdobeCrashReporter 6.0.20120720
AdobeExtendScript.framework AdobeExtendScript 4.2.12.18602 66.490082
AdobeJP2K.framework AdobeJP2K 2.0.0.18562 66.236923
AdobeLinguistic.framework 17206
AdobeMPS.framework AdobeMPS 5.8.0.19463 66.495174
AdobeOwl.framework AdobeOwl 5.0.4 79.517869
AdobePDFL.framework AdobePDFL 10.0.1.18562 66.419471
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 7.0.0.1686
AdobeScCore.framework AdobeScCore 4.2.12.18602 66.490082
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 66.145661 66.145661
AdobeXMPFiles.framework AdobeXMPFiles 66.145661 66.145661
AdobeXMPScript.framework AdobeXMPScript 66.145661 66.145661
ahclient.framework ahclient 1.7.0.56
aif_core.framework AdobeAIF 3.0.00 62.490293
aif_ocl.framework AdobeAIF 3.0.00 62.490293
aif_ogl.framework AdobeAIF 3.0.00 62.490293
AlignmentLib.framework xcode 1.0.0.1
amtlib.framework amtlib 6.0.0.75
boost_date_time.framework boost_date_time 6.0.0.0
boost_signals.framework boost_signals 6.0.0.0
boost_system.framework boost_system 6.0.0.0
boost_threads.framework boost_threads 6.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.1.0.20577 146758
data_flow.framework AdobeAIF 3.0.00 62.490293
dvaaudiodevice.framework dvaaudiodevice 6.0.0.0
dvacore.framework dvacore 6.0.0.0
dvamarshal.framework dvamarshal 6.0.0.0
dvamediatypes.framework dvamediatypes 6.0.0.0
dvaplayer.framework dvaplayer 6.0.0.0
dvatransport.framework dvatransport 6.0.0.0
dvaunittesting.framework dvaunittesting 6.0.0.0
dynamiclink.framework dynamiclink 6.0.0.0
FileInfo.framework FileInfo 66.145433 66.145433
filter_graph.framework AdobeAIF 3.0.00 62.490293
hydra_filters.framework AdobeAIF 3.0.00 62.490293
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
image_compiler.framework AdobeAIF 3.0.00 62.490293
image_flow.framework AdobeAIF 3.0.00 62.490293
image_runtime.framework AdobeAIF 3.0.00 62.490293
LogSession.framework LogSession 2.1.2.1681
mediacoreif.framework mediacoreif 6.0.0.0
PlugPlug.framework PlugPlug 3.0.0.383
UpdaterNotifications.framework UpdaterNotifications 6.0.0.24 "6.0.0.24"
wrservices.framework
Required plug-ins:
Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 7.3 (71), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Difference Clouds 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Measurement Core 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
MMXCore Routines 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Picture Package Filter 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 13.0.4 20130104.r.28 2013/01/04:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins:
Accented Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - from the file “AdobeADM.bundle”
Angled Strokes 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1993-2011 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Chalk & Charcoal 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©2002-2011 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1993-2011 Adobe Systems Incorporated - from the file “Clouds.plugin”
Color Halftone 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©2003-2011 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Difference Clouds 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1993-2011 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1997-2011 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Extrude 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Fibers 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Fresco 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Graphic Pen 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 12.0, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
Hidden Topaz Labs Denoise - from the file “TopazRemaskAutomate.plugin”
IFF Format 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 12.0x001 ©2001-2008 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Lens Blur 12.0, Copyright © 2002-2010 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 12.0.2, Copyright © 2002-2010 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 12.0.1, Copyright © 2001-2010 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1993-2011 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Measurement Core 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1993-2011 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Mezzotint 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Mosaic Tiles 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Neon Glow 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1993-2011 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
OpenEXR 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1989-2011 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PhotoTools 2.6 2.6.4, Copyright © 2011 onOne Software. All rights reserved. - from the file “PhotoTools 2.6.plugin”
PhotoTools 2.6 Batch 2.6.4, Copyright © 2011 onOne Software. All rights reserved. - from the file “PhotoTools Batch.plugin”
PhotoTools 2.6 Hidden NO VERSION - from the file “HelperFilter.plugin”
Picture Package Filter 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1993-2011 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1989-2011 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1989-2011 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©2003-2011 Adobe Systems Incorporated - from the file “Radiance.plugin”
Reticulation 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 12.0, Copyright © 1999-2010 Adobe Systems Incorporated - from the file “Save for Web.plugin”
Shear 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smart Blur 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1993-2011 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sumi-e 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Targa 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Topaz Adjust 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_adjust5.plugin”
Topaz BW Effects CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_BW_Effects.plugin”
Topaz Clean 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_clean3.plugin”
Topaz DeJpeg 4 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_dejpeg4.plugin”
Topaz DeNoise 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_denoise5.plugin”
Topaz Detail 2 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_detail2.plugin”
Topaz InFocus CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_infocus.plugin”
Topaz Lens Effects CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_Lens_Effects.plugin”
Topaz ReMask 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_remask3.plugin”
Topaz Simplify 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_simplify3.plugin”
Torn Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Underpainting 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 12.0, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Water Paper 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch] ©1989-2011 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Plug-ins that failed to load:
Lighting Effects Classic NO VERSION - 32-bit plug-in not supported in 64-bit - from the file “Lighting Effects.plugin”
Multiprocessor Support NO VERSION - - from the file “MultiProcessor Support”
Send Video Preview to Device NO VERSION - 32-bit plug-in not supported in 64-bit - from the file “FireWire Export.plugin”
Variations NO VERSION - 32-bit plug-in not supported in 64-bit - from the file “Variations.plugin”
Video Preview NO VERSION - 32-bit plug-in not supported in 64-bit - from the file “FireWire Export.plugin”
Flash: NONE
Installed TWAIN devices: NONE
If the memory flucutates check OS vitals and see if it does same there also. Then run a memory test. Probably either a failing memory bank, or a bad connection. If you can open up computer go in and push on the memory sticks and make sure they are making good connection. Beware of static electricity and ground your finger to metal case before touching anything.
Go delete EVERYTHING you copied to the plugins folder. Yes EVERYTHING.
That was a huge mistake.
The plugins folder for CS6 is only for third party plugins.
And you should never copy Adobe plugins from version to version like that.
North America
Asia Pacific
