proxies
Mar 6, 2013 8:10 AM
Using a proxy is a great help. But i ran into a problem of Premiere using the low-res proxy in the final render of my project. I assumed Premiere, or After Effects, would have the brains to not use low-res proxies when it comes to outputting a final render.
My next project will have numerous 'replace with ae' clips - do i have manually go back and forth turning off proxies when i want to do final render?
    Mar 6, 2013 8:13 AM   in reply to WebOfWebs
    See the Render Settings section in After Effects Help. You can choose in the render settings whether to use proxies or not for a given render operation.
    Mar 7, 2013 8:14 AM   in reply to WebOfWebs
    > However i've read that page (numerous times unfortunately) and i'm still not getting it!
    Here's the most relevant part from the render settings section:
    Proxy Use
    Determines whether to use proxies when rendering. Current Settings uses the settings for each footage item.
