XColomer
Weird Shader Behavior
Mar 6, 2013 10:28 AM
Tags: #stage3d #shaders
Hi There,
This question has also been posted in SO:
http://stackoverflow.com/questions/15255004/weird-shader-behavior-in-s tage3d
I am using this vertex Shader:
<script id="per-fragment-lighting-vs" type="x-shader/x-vertex">
    attribute vec3 aVertexPosition;
    attribute vec3 aVertexNormal;
    attribute vec2 aTextureCoord;
    uniform mat4 uMVMatrix;
    uniform mat4 uPMatrix;
    uniform mat3 uNMatrix;
    varying vec2 vTextureCoord;
    varying vec3 vTransformedNormal;
    varying vec4 vPosition;
    void main(void) {
        vPosition = uMVMatrix * vec4(aVertexPosition, 1.0);
        gl_Position = uPMatrix * vPosition;
        vTextureCoord = aTextureCoord;
        vTransformedNormal = uNMatrix * aVertexNormal;
</script>
But all I can see is tiles instead the object correctly textured.
If I edit the shader like this:
<script id="per-fragment-lighting-vs2" type="x-shader/x-vertex">
    void main(void) {
        gl_Position = uMVMatrix * vec4(aVertexPosition, 1.0);
</script>
And premultiply the perspective in actionsctript I can see the object correctly mapped although it has a different perspective
Any suggestion?
