adfg_jadaily
Changing Keyboard Shortcuts in Spark DataGrid
Mar 6, 2013 1:07 PM
Tags: #as3 #flex-4.6 #spark #datagrid #4.5.1 #itemeditor
What I'm trying to do seems like it should be pretty simple:  there are item editor shortcuts for the default item editor in a Spark DataGrid, such as Ctrl-Enter to save the edited data and move down one row within a column (like typing in a number in a cell in Excel and then pressing Enter).  I would like to change it so that instead of pressing Ctrl-Enter, the user only needs to press the down arrow.  However, I don't know whether I should be subclassing the DefaultGridItemEditor, or if I should be putting event handlers for KeyboardEvent.KEY_DOWN on the datagrid, or the application, or what.
I'm guessing I need to subclass GridItemEditor, so here's what I have so far:
<s:GridItemEditor xmlns:fx="http://ns.adobe.com/mxml/2009"
                  xmlns:mx="library://ns.adobe.com/flex/mx">
    <fx:Script>
        <![CDATA[
            // Override the prepare function to set an event listener
            // on the KeyDown event, to listen for presses of the Down arrow
            override public function prepare():void {
                this.addEventListener(KeyboardEvent.KEY_DOWN,downArrowHandler,true,10000);
            private function downArrowHandler(event:KeyboardEvent):void {
                if(event.keyCode == Keyboard.DOWN) {
                    event.target.dispatchEvent(new KeyboardEvent(KeyboardEvent.KEY_DOWN,true,true,0,13,KeyLocation.STANDARD,true));
            override public function set value(newValue:Object):void {
                input.text = newValue as String;
            override public function get value():Object {
                return input.text;
            override public function setFocus():void {
                input.setFocus();
    </fx:Script>
    <s:TextInput id="input" width="100%"/>
</s:GridItemEditor>
What I'm trying to do is listen for a press of the Down arrow and dispatch a keyboard event for Ctrl-Enter, because I thought that might be easier with manually saving and then moving down to the next row in the same column.  This does not seem to be working, though.  Any ideas?
    Mar 7, 2013 6:19 AM   in reply to adfg_jadaily
    You could simplify your code by using a switch statement, which would allow you to access whatever keyboard action you want to track without going through a bunch of "if else" statements.
    i.e.
    switch(event.keyCode) {
          case Keyboard.DOWN:
               dataGrid.endItemEditorSession();
               dataGrid.setSelectedCell(dataGrid.selectedCell.rowIndex + 1,dataGrid.selectedCell.columnIndex);
               dataGrid.startItemEditorSession(dataGrid.selectedCell.rowIndex,dataGrid.selectedCell.columnIndex);
          break;
          case KeyBoard.UP:
              dataGrid.setSelectedCell(dataGrid.selectedCell.rowIndex - 1,dataGrid.selectedCell.columnIndex);
          break;
    of course, more simplified would be this
          case Keyboard.DOWN:
          break;
          case KeyBoard.UP:
          break;
