importing flash 3d animation into after effects
Mar 6, 2013 3:50 PM
I have to create an animated video for my boss of silhouettes of baseball players on a baseball field. All the baseball players would be flat images. The field would be like an over head image of the field, but 3d rotated so it is 90 degrees with the players. In FLASH I could do this by making a movie clip with the field and the players in it. Then make the players movie clips and 3d rotate them 90 degrees to the screen. After that, go outside the first symbol and 3d rotate that and move it around. The problem I with having with FLASH was that when I would 3d rotate the field in the middle of the screen it would rotate away from the left side of the screen. So, my question is could I build the feild and players in flash and import the 3d symbol into AFTER EFFECTS and still 3d manipulate. Or, is there a way to change where movie clips 3d rotate away from in FLASH? I will post this on both AFTER EFFECTS and FLASH's discussions. I would really appreciate it if everyone who reads this answers both questions. Thank you.
    Mar 6, 2013 5:15 PM   in reply to Rama1234ish
    You cannot import 3D elements from flash into AE and have them stay 3D. You can, however, create shapes in AE or import Illustrator or Photoshop artwork and make them 3D layers and create your ball field entirely inside AE.
    Mar 6, 2013 7:18 PM   in reply to Rama1234ish
    You can do anything you want. You can parent all the shapes to a null and move the null, you can arrange the objects on a 3D stage and move a camera around them. Before you try and do any of these things you MUST go through some training materials. AE is not a program that you can just pick up and use. You must be familiar with layers, blend modes, keyframes, masking, 3D scene setup, 3D cameras just to get started. Then their's rendering, frame rates, output options... AE can produce anything from an animated gif to an IMAX spectacular. You just need to know how to use the tools. Start Here.
    Mar 25, 2013 5:21 PM   in reply to Rick Gerard
    I agree with Rick.  I would try and create your 3D field in After Effects.  Check out some tutorials.  Here's one that might be helpful:
    http://tv.adobe.com/embed/926/16313/
    Mar 12, 2013 12:11 PM   in reply to Rama1234ish
    Post a screenshot. You've just not got some switch turned on.
    Mar 25, 2013 8:41 AM   in reply to Rama1234ish
    good job Rama!
    Mar 25, 2013 8:48 AM   in reply to BenjaminMarkus
    Great tutorial there Ben!
