I need to enter a checkmark (unicode u2173) in an Illustrator drawing: surely, in 2013, this ought to be easy? but as an occasional Illustrator user I'm not having much success :-{ Illustrator CS5 on Win 7 … hints and tips welcome!
The "local font list" tool at www.fileformat.info, which I have found generally reliable, tells me that I have quite a few fonts on this PC that include U+2713. (even if the actual glyphs in the blackletter and script fonts looked wildly out of place) En passant, I'd be the first to say there are far too many fonts installed on this "corporate" PC, but that's a different question ;-}
Arial Unicode MS is one of them, and I eventually tracked it down in the fonts pulldown. The snag I ran into was not so much a question of font, as of access. U+2713 is in the Dingbats block, which is not listed in the "Show" pulldown of the Glyphs panel – so I had to scroll determinedly up and down the list and hover over a character every now and then to see where I was. I would prefer to insert a Unicode glyph quickly and efficiently by entering its U+ code – or from a panel like the one in Adobe FrameMaker.
But thanks for the tip, as I have now been able to use the glyph I needed …
There is a Windows hack involving some registry editing, but it has been noticed this doesn't work with "all" software.
For InDesign I use a simple, short Javascript -- and I stored it under a hotkey. Unfortunately, that's not an option with Illustrator! This quick adjustment of one of the sample scripts seems to do the job just fine, but its usefulness is reduced by having to call it up through File -> Scripts -> (browse for script) -> Enter ....
// if a document is open
if(documents.length >0)
// if textframes exist in the document
if(activeDocument.textFrames.length > 0)
// check to make sure something is selected.
selectedItems = selection;
if (selectedItems.typename == "TextRange")
ucchar = prompt("Unicode character (hex)", "2713");
if (ucchar)
// alert ("The following text is selected: >" + selectedItems.contents + "<");
if (ucchar.match(/^[0-9A-F]+$/i))
selectedItems.contents = String.fromCharCode(parseInt(ucchar,16));
} else
alert ('Bad Unicode "'+ucchar+'"');
else
alert("No text is selected.");
else
alert("Open a document and select 1 or more text items or a text range.");
else
In Windows you can use keyboard shortcuts to enter characters that are not on the keyboard: hold down the left Alt key, then enter the decimal number of the U+ code, preceded by a zero. For instance Alt+0165 (U+00A5) would produce the '¥' sign.
Similarly Alt+010003 (U+2713) or Alt+010004 (U+2714) would produce ✓ and ✔. That works nicely in MS Word, but unfortunately not in Illustrator - I don't know why.
North America
Asia Pacific
