How to grep connectors in a group, between two required words?
Mar 7, 2013 2:52 AM
Must catch some connectors between two words in a very extensive document.
1     Joanna de Smith
2     Felicitas de la Tour
3     Perpetua y Beatrice Kennedy
but the solution is very poor resolved in three steps and it seems should be just only one string.
1     <\u\l{2,}de ( \u\l{2,})+\>
2     <\u\l{2,} de la ( \u\l{2,})+\>
3     <\u\l{2,}y ( \u\l{2,})+\>
    Mar 7, 2013 5:42 AM   in reply to camilo umaña
    (?<=\l )(de)( la)?|y(?= \u)
    seems to work on your example text.
    Mar 7, 2013 11:50 AM   in reply to camilo umaña
    Try this one:
    (( ?\u\l+)+(( de)( la)?| y)( \u\l+)+)
    It seemed to work when I tested it on your sample.
    Mar 7, 2013 12:41 PM   in reply to camilo umaña
    And thanks to Peter Spier as well. I used large parts of the code he wrote to work out this one.
    > beautiful! i have to study the use of aditional (()).
    The most important "extra" parentheses here are the ones that Peter S. inadvertently left out:
    ( de( la)?| y)
    The vertical pipe | is the OR operator, and if you do NOT use it inside a parenthesized expression, it splits the *entire* expression in two halves. So Peter's matched either "Juan de la" OR "y Cetera". The extra set of parentheses around this -- and only this -- part of the expression limits the OR to just this part.
    Mar 7, 2013 3:05 PM   in reply to [Jongware]
    ( de( la)?| y)
    Wasn't inadvertant at all. It was out of ignorance.
    Where were you this morning?
    I thought I was rather clever, though, figuring out the conditonal "la" and the "or" part, and combining it with the lookarounds (because I misunderstood the intent -- thought all he wanted was the connectors).
    Mar 8, 2013 5:18 AM   in reply to camilo umaña
    Maybe you should tell us again just exactly waht you are trying to do (find). You want to find all proper names, whether they have a connector or not?
    Mar 8, 2013 6:33 AM   in reply to camilo umaña
    Make the entire connection part *optional* by following it with a ? like this:
    (( ?\u\l+)+(( de)( la)?| y)?( \u\l+)+)
