Challenge: a screen of 12,273 x 1080 px is divided into 560 tiles of 153 x 153 px, 7 rows by 80 columns.
I want to be able to map a single image across all tiles with the ability to individually alter the colour balance of tiles to look like a pseudo mosaic...
THEN...
I want the tiles to randomly drop - as though fallling off a wall - until they vanish off the bottom of the frame to reveal a new image on the lower layer. This cycle repeats.
Manually separating and colour adjusting each image into 560 pieces is impractical becase of the timescale and the shear number of images. I have produced a master grid in Illustrator consisting of 560 separate tiles. Is there a way of using this as a bump map in some way to create different colour/tone maps? I have imported this ito AE as separate layers, but cannot find a way of animating them realistically. Applying vertical position keyframes to 560 layers is not possible in the timescale.
Card Dance and Card Wipe are too contrived and regular for the tile drop to look realistic/random, and don't allow velocity.
Any hints for all or part of what I'm trynig to achieve would be extremely welcome.
Card Dance can use an image to set a random pattern for the tiles to move. Shatter can also use gradients or colors fot custom maps and custom shapes. These are your easiest options. You could also use a mosaic color pattern as an overlay with color blend mode to change the color balance of the sections.
Look here for advanced Card Dance.
Look here for advanced Shatter Maps.
Let me know if you need help on blend modes.
Thanks Rick.
Unfortunately I tried that Advanced Card Dance Tut earlier, but received the infamous 404. I'll contimue to search, but thanks anyhow.
When you suggest a mosaic colour pattern overlay, do you mean create a master grid with varying greyscale squares in, say, Photoshop, and using blend mode on this, or actually colouring the tiles and using these in blend mode.
Much appreciated.
North America
Asia Pacific
