vaughan38
Bridge  not opening up from task bar windows 8
Mar 7, 2013 8:37 AM
Tags: #bridge #cs6
recently purchased  adobe creative suite  6 design  student and teacher addition  loaded it onto  windows  8  was working for a while  but  now it appears that  bridge will  not open onto the full screen from the task  bar  other programs okay at the  moment . Mini bridge  functions in photo  shop.
Any  help would be greatly appreciated thank you
    Mar 7, 2013 8:58 AM   in reply to vaughan38
    Hi vaughan38,
    When you are able to Open Bridge,In Bridge go to Window/Workspace and reset it.
    I.M.H.O. This should do the Trick!
    Cheers!
    Mar 7, 2013 11:14 AM   in reply to vaughan38
    Can you please add some screenshots of the problem you area facing and highlight it, if et'all you can.
    Also,
    • What happens when you click Bridge?
    • Did you try re-installing PS?
    Mar 7, 2013 11:26 AM   in reply to vaughan38
    Can you try resetting the preferences of Bridge.
    • Start Adobe Bridge and immediately press Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) until the Reset Settings dialog box appears.
    • Select all three options--Reset Preferences, Reset Standard Workspaces, and Purge Entire Thumbnail Cache--and then click OK.
      [Moved to Bridge forums]
    Mar 8, 2013 1:50 PM   in reply to vaughan38
    The preferences have gone corrupt which we have resetted, it is hard to say how they got corrupted.
    Just check and if the issue re-appreas let us know.
    Mar 8, 2013 5:45 PM   in reply to Manish-Sharma
    It is quite a bit simpler with resetting prefernces in Bridge to just press and hold Crtl key and start Bridge.
    Mar 11, 2013 1:53 AM   in reply to Curt Y
    Thanks Curt.
    its an Old InDesign preference reset habit
