how to setup a default size for new divs in fluid grid layout in dreamweaver?
Mar 7, 2013 11:23 PM
Tags: #image #size #div #dreamweaver #layout #html5 #cs6 #fluid #grids #divs
how to setup a default size for a new divs in fluid grid layout in dreamweaver? I don't need the default size for new divs as a 100% width, I need them 13.69% as a one coulmn width only (7 coulmns fluid grids layout for desktop size 1000w).
This problem I've faced when I intended to insert dozens of fluid grid divs in the layout.
    Mar 8, 2013 3:29 AM   in reply to Marzoog
    Mar 8, 2013 7:18 PM   in reply to Marzoog
    Sorry, I don't believe that you have had a good look at the Foundation framework. I'll now hold your hand while we go through the basics.
    Here is the specific page http://foundation.zurb.com/docs/components/grid.html
    The default values are
    Em-base : 16px
    Row width: 62.5em (62.5em x 16px = 1000px)
    Columns per row: 12
    These and other default values can be changed. The fact of the matter is that if you stipulate a section width of 2 or 3 or 12 columns, the widths will automatically be calculated for you.
    In your case, if you want 7 columns, all you need to do is change the number of columns per row and the rest is done for you.
    Mar 11, 2013 2:51 AM   in reply to Marzoog
    You will need to change percentages in the CSS as in
      .row .large-5 {
        position: relative;
        width: 71.42857%; }
      .row .large-6 {
        position: relative;
        width: 85.71428%; }
      .row .large-7 {
        position: relative;
        width: 100%; }
    The default value is 12 columns instead of 7 columns with good reason.
    Twelve can be divided by 1, 2, 3, 4, 6; seven can be divided by ?????
    Think about it!
